I’m using the Call Service node in a flow to notify HA that a new call is arriving via my Obi 202 telephone adaptor. When I use test data to populate msg.payload with:
“{ “data”: {“title”:“New Phone Call”,“message”:“12065231111 name Jack Be Quick” } }”
I see that msg.payload.data contains two properties:
title: “New Phone Call”
message: “12065231111 name Jack Be Quick”
However, when I take the data from the Obi Device and, using the same function node to prepare the JSON string, which is formatted identically, and which passes JSONLint as valid JSON, msg.payload.data ends up empty. I can’t find a difference in the data, except the value of the message property, which will change from call to call. I’m baffled.
Ub
