I made this Flow for testing (inject payload “3”, function-node convert to number, action-node should write it to HA-helper)
"id": "14a65c9e1077d2d8",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "777b263b71e0b421",
"type": "debug",
"z": "14a65c9e1077d2d8",
"name": "Show Total Sum",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 380,
"y": 80,
"wires": []
"id": "1b12bbf864ea7f1d",
"type": "api-call-service",
"name": "heute",
"server": "48453e273e9641c6",
"version": 7,
"debugenabled": false,
"action": "number.set_value",
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"counter.brum"
"labelId": [],
"data": "{ \"value\": $number(payload) }",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"blockInputOverrides": true,
"domain": "number",
"service": "set_value",
"x": 350,
"y": 120,
"wires": [
"id": "e230544389dcf758",
"type": "inject",
"name": "test",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "3",
"payloadType": "num",
"x": 150,
"y": 200,
"wires": [
"36412e946cd82735"
"id": "36412e946cd82735",
"type": "function",
"name": "function 1",
"func": "msg.payload = Number(msg.payload); // Stelle sicher, dass es eine Zahl ist\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 300,
"y": 200,
"wires": [
"777b263b71e0b421",
"1b12bbf864ea7f1d"
"id": "48453e273e9641c6",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30,
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": ": ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "default",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
normally, Node-Red should write “3” in HA-helper “counter.brum”, but this does not happen.
Does anybody know what I can do to fix this?
Thanks.
