NODE-RED Cannot interact with any buttons on nodes (timestamps, debug nodes) Cannot see values and trigger times of nodes
See this in logs
Logger: homeassistant.const
Source: helpers/deprecation.py:197
STATE_UNLOCKED was used from nodered, this is a deprecated constant which will be removed in HA Core 2025.10. Use LockState.UNLOCKED instead, please report it to the author of the ‘nodered’ custom integration
I can’t believe we still have this issue… I was hoping later updates would solve it, but so far nada… I still have to do everything via the Node Red port which is annoying…
If clicking the outside link is really bothersome,
Then you will have a link from your sidebar and it will look and work just like the link the addon supplies.
Thanks, :slight_smile: - that’s cheating though! I want to know what is causing this as clearly it is not the same for everyone
Hello all, this is my first post (so please be kind)… I believe I have solved the node-red timestamp not active issue. (very simple solution).
steps:
1 - in node-red, click on the “hamburger” icon (3 parallel bars) in the upper right hand of the screen, then select “settings” (4th item from the bottom of the dropdown list)
2 - in the pop-up window, select the “Palette” tab (left hand side)
3 - review all the items and click on “update” box for any/all items that have an update (pending) and close that tab. (you can update them all before the next step)
4 - (restart the node-red add-on) settings>add-ons>select node-red and click on restart.
5 - all buttons should now work.
Apparently, various palettes needed to be updated to make everything work again.
hope this helps others!
see my post below on how to do this… you simply need to update the palettes in your node-red.
This fixed all of my flows.
good luck
Ok so I deleted my node-red connection to
HA and created a new one. All works now
