Hey there, guys! Can anyone tell me why I cannot press the timestamp button in any of my flows? The debug button also doesn’t work I have to keep reloading the page until it does. Homeassistant’s companion app and other browsers behave similarly. Uninstalling most of the pallets I installed in the past months hasn’t made any difference. Log seems to be clear, except for this : “[warn] Projects disabled : editorTheme.projects.enabled=false”
This was the only way to capture the cursor, so I apologize for not posting a printscreen.
Check that you are doing a full deploy (down arrow on the deploy button)
Check that you are using the right server node (Configuration Nodes - Gear in the upper right corner)
Not at all If I really need it to work, I just have to keep reopening the node-red, which can take up to an hour of my time.
Edit: since I commented I have not been able to make it work again…
Get Node Red started even if you have to wait hours.
Then check if nay palettes need to be updated and also check if any nodes are linked to wrong servers. One of the icon in the upper right menu should give you an overview of you elements with number of connections.
Aside from bad/extra configuration nodes and nodes that need updating, for home assistant addon users directly accessing NR could correct this. Use your HA IP with 1880 instead of 8123. Use your user name and password from home assistant to access the page.
So the next time I tried it failed. I had to go directly to the node red interface using the suggestion above (1880) and that failed too until I restarted the flows from there. I think it might be random at this point. Click on the deploy drop down and you will see it as the last option.
