Node-red cant start
after i deployed one of the nodes, my node-red stopped and cant start anymore.
I have rebooted the HA, reinstalled NR, but nothing helps.
the error during start of the NR is:
28 Apr 14:20:34 - [red] Uncaught Exception:
28 Apr 14:20:34 - [error] TypeError: Cannot read properties of null (reading 'status')
    at /config/node_modules/node-red-contrib-mi-devices/node-red-contrib-xiaomi-gateway/xiaomi-gateway.js:103:41
    at Object.eachNode (/opt/node_modules/@node-red/runtime/lib/flows/index.js:263:13)
    at Socket.<anonymous> (/config/node_modules/node-red-contrib-mi-devices/node-red-contrib-xiaomi-gateway/xiaomi-gateway.js:97:31)
    at Socket.emit (node:events:517:28)
    at UDP.onMessage (node:dgram:942:8)
[14:20:34] INFO: Service Node-RED exited with code 1 (by signal 0)
Where are the flows stored? can I delete the flow in the text file? If not, what else should I do?
Thanks,
Michal
Go to the add on, configuration tab. There is an option for safe mode, turn it on. restart NR. Remove those nodes mentioned in the error. Turn off safe mode, restart NR.
Thanks,
I am a newbie in HA, did not know about it
Now I have different warning message and NR don’t start anyway.
28 Apr 18:39:41 - [warn] ------------------------------------------------------
28 Apr 18:39:41 - [warn] [node-red-contrib-mi-devices/xiaomi-yeelight] Error: Cannot find module '/config/node_modules/node-red-contrib-mi-devices/dist/nodes/yeelight/index.js'
Require stack:
- /opt/node_modules/@node-red/registry/lib/loader.js
- /opt/node_modules/@node-red/registry/lib/index.js
- /opt/node_modules/@node-red/runtime/lib/nodes/index.js
- /opt/node_modules/@node-red/runtime/lib/index.js
- /opt/node_modules/node-red/lib/red.js
- /opt/node_modules/node-red/red.js
What I am doing wrong?
Edit:
It’s running now. So the second part - deleting the problematic node.
Thank you!
Michal
