Hi All,
I thought this was going to be simple but not having much luck.
What i want is if the TV is paused and my lights are already a set color and brightness (set from a scene), then increase the brightness. If then the TV is unpaused then set brightness back down.
As this is from scene i know the values,
When TV pause is set, if light state on and brightness: 15 and rgb_color:[0,0,255]
Then set light brightness 255
When TV resumed if light state on and brightness: 255 and rgb_color:[0,0,255]
Then set light brightness 15
If this light was not already set to this scene then don’t change. (dull blue being move “Movie mode”)
The triggers are easy enough as doing on state changed, but i cannot get the if rgb_color:[0,0,255] to work, testing the strings or numbers are easy enough but i have not been able to work out how to compare against an array.
Any pointers as to which node(s) to use and how to set it would be great as tried all sorts of combinations.
