Node-red "connecting" after 0.105.2
Hi
I just updated from 0.104.3 to 0.105.2 and now I get a “connecting” in node-red?
Am I missing a setting?
Fixed it.
Set a new password in “credential_secret” - restart add-on.
Changing “credential_secret” back to the old password - restart add-on.
That did the trick :slight_smile:
This fix didn’t work for me. Has anyone found any alternative? I’m still left with the connecting issue after resetting the credential_secret + restarting then resetting the credential_secret + restarting again.
This started happening after upgrading to 0.105.2
No problems for me running HAC 0.105.2 and NodeRED v1.0.3 :slight_smile:
Are you restarting the add-on or your home assistant?
Yes, I was restarting the node-red add-on. I also tried clearing the cache restarting the home assistant. I reverted back to 0.104.3 and node-red connected again. I saw 0.105.3 was released today, so I’ll see if I have better luck with that version.
I wanted to let you know I had no issues when upgrading to 0.105.3.
Thx. I will give 0.105.3 a try :+1:
So my connecting issue has returned in Home Assistant 0.105.4. I tried deleting my node red plugin and reinstall it along with all the settings. The problem still exists so I don’t think it’s a problem with my specific install.
Is anyone else still seeing this issue with node red?
No issues for me!
Screenshot 2020-02-17 at 01.15.39
Running HAC 0.105.4 with Node-RED v1.0.3 :slight_smile:
Okay, I’m running node red version 6.0.4 in HassOS 3.11.
Maybe that’s the difference.
I was hoping to see more people with this problem before posting my logs. Since this happened after a version update, and everything was working before the update, I assumed others would have issues too.
The node-red logs show
[error] [server:Home Assistant] [object Object]
…which is not super useful.
In the node-red logs, I consistently see
[info] [mqtt-broker:Hassio Mosquito Broker] Connection failed to broker: node-red@https://192.168.xx.xx
The Mosquito Broker logs show the following for all clients trying to connect
Socket error on client <unknown>, disconnecting
I see this error in the system logs
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x719bedc0>; the handler is closed
20-02-18 20:52:56 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<WebSocketWriter.ping() done, defined at /usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py:631> exception=RuntimeError('unable to perform operation on <TCPTransport closed=True reading=False 0x719d8dc0>; the handler is closed')>
I assumed the issue would go away after future updates, but after a few updates since 0.105 the Node-Red connection issue still persists. Does anyone have an idea what could be the root cause of this problem?
For people Googling, Node-RED will show Home Assistant elements as “Connecting” if your Home Assistant is still starting up. This includes if you have an integration preventing HA from starting up completely.
