Node-red-contrib-home-assistant-websocket keeps uninstalling on HA reboot
This is weird. Everytime I reboot HA (manually or due to power failure), my NodeRed flows stop working - the principle problem being that it loses the nodes for communicating with Home Assistant
Each time I find the node-red-contrib-home-assistant-websocket component is no longer installed in NodeRed’s Pallette.
I manually reinstall it and all is fine. Until it reboots, then it’s gone…
Also - after installing, the component is showing it is at version 0.59.0 with an option to upgrade to 0.62.2 - attempts to do this upgrade fail and leave it at 0.59.0
I have tried uninstalling and reinstalling NodeRed - same problem.
Any suggestions as to what to try next? I have root ssh access to the RPi on 22222 so I can look internally…
HA is running on a RPi, versions:
  • Core2023.12.4
  • Supervisor2023.12.0
  • Operating System11.2
  • Frontend20231208.2
Don’t upgrade past 0.59.0 unless you have Node-RED v3.1.1
If you are using Node-RED as an addon, then DO NOT update the WebSocket nodes.
If you have a free-install of Node-RED, then update Node-RED to the latest version.
https://community.home-assistant.io/t/warning-do-not-update-websocket-to-0-61-1-with-add-on-version-16-0-2/653887/1
Bit late to reply, but just for completeness - this issue did fix itself eventually.
