Node-red-contrib-hourglass doesn't output anything
Hi. Just playing around with the node-red-contrib-hourglass node and didn’t manage to output anything. So I imported the basic flow from the documentation but it doesn’t output anything either.
Can anybody help or is it just broken?
[{"id":"92109e0a.88d96","type":"hourglass","z":"26a14c0c.360194","name":"","humanizeLocale":"","x":751,"y":80,"wires":[["f8480416.0850d"]]},{"id":"5a0a72af.5c5fc4","type":"change","z":"26a14c0c.360194","name":"{command:'reset'}","rules":[{"t":"set","p":"command","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":464,"y":180,"wires":[["5f57def2.775bb","92109e0a.88d96"]]},{"id":"cfff0e2d.ada0e8","type":"change","z":"26a14c0c.360194","name":"{command:'start'}","rules":[{"t":"set","p":"command","pt":"msg","to":"start","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":462,"y":80,"wires":[["5f57def2.775bb","92109e0a.88d96"]]},{"id":"a0a2d80e.88f7d","type":"change","z":"26a14c0c.360194","name":"{command:'stop'}","rules":[{"t":"set","p":"command","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":462,"y":120,"wires":[["5f57def2.775bb","92109e0a.88d96"]]},{"id":"f8480416.0850d","type":"debug","z":"26a14c0c.360194","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"elapsed.millis","targetType":"msg","x":981,"y":80,"wires":[]},{"id":"5f57def2.775bb","type":"debug","z":"26a14c0c.360194","name":"last command","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"command","targetType":"msg","x":761,"y":140,"wires":[]},{"id":"5d200463.e6e644","type":"inject","z":"26a14c0c.360194","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":120,"wires":[["a0a2d80e.88f7d"]]},{"id":"894f06df.59219","type":"inject","z":"26a14c0c.360194","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":180,"wires":[["5a0a72af.5c5fc4"]]},{"id":"f8935576.4a4ae","type":"inject","z":"26a14c0c.360194","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":80,"wires":[["cfff0e2d.ada0e8"]]},{"id":"6384eb1d.90bca4","type":"inject","z":"26a14c0c.360194","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":220,"wires":[["5bb3a7b5.cb8b9"]]},{"id":"5bb3a7b5.cb8b9","type":"change","z":"26a14c0c.360194","name":"{command:'status'}","rules":[{"t":"set","p":"command","pt":"msg","to":"status","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":462,"y":220,"wires":[["92109e0a.88d96","5f57def2.775bb"]]}]
What are you trying to do?
If you just want to measure a flow, then set an attribute in the beginning like msg.start_time=timestamp and the same in the end, like msg.stop_time=timestamp
