Particulars/Requisites
Raspberry:P4
Router: Tplink Archer a7 (AC1750)
Home Assistant version:
Node Red:v2.2.0
Node: JS:v16.13.2
Narrative
I created a fresh installation of Home Assistant/Node Red. Subsequently I installed the “node-red-contrib-sonos-plus” nodes from the Node Red Palette. Prior to this installation I created a “reserved” IP4 address for the “coordinator.” My coordinator is the one speaker in my Sonos system connected to the router via ethernet.
90% of the time on system start up the upstream connection to coordinator (Ethernet connected sonos speaker) fails and I get a failure to connect message
10% of the time the plugin successfully connects upstream to the coordinator and the plugins nodes work normally
Note: My TP link Archer A7 router does not offer Static IP. I also do not have DDNS capability.
Issue:
Why is my connection success rate “intermittent”, instead of “success/fail”? why is it so low? How do I improve the connection percentage to an acceptable level? Do I need a better router that can do a static iP instead of a reserved IP, Do I need DDNS, what an I missing???
Logs below
Welcome to Node-RED
2 Feb 10:50:06 - [info] Node-RED version: v2.2.0
2 Feb 10:50:06 - [info] Node.js version: v16.13.2
2 Feb 10:50:06 - [info] Linux 5.10.63-v8 arm64 LE
2 Feb 10:50:08 - [info] Loading palette nodes
2 Feb 10:50:17 - [info] Dashboard version 3.1.5 started at /endpoint/ui
2 Feb 10:50:18 - [info] Settings file : /etc/node-red/config.js
2 Feb 10:50:18 - [info] Context store : 'default' [module=memory]
2 Feb 10:50:18 - [info] User directory : /config/node-red/
2 Feb 10:50:18 - [warn] Projects disabled : editorTheme.projects.enabled=false
2 Feb 10:50:18 - [info] Flows file : /config/node-red/flows.json
2 Feb 10:50:18 - [info] Server now running at http://127.0.0.1:46836/
2 Feb 10:50:18 - [info] Starting flows
2 Feb 10:50:18 - [error] [sonos-universal:f51aee9d8314e0ba] create and subscribe: serial number/ipv4//DNS name are invalid :: Details: none
[10:50:19] INFO: Starting NGinx...
2 Feb 10:50:23 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Feb 10:50:24 - [info] [server:Home Assistant] Connected to http://supervisor/core
Cheers,
Craig
