Node-Red Dashboard
Hello
I really like using Node-Red and I’m learning how to use the dashboard as well. Node-Red run on Raspberry Pi 3+ in Hassio Home Assistant. As the subject says, after update Node-red- when I load the Dashboard:
How to open the dashoard created ?
Node-Red Dashboard
I run node red on a seperate pi3, but I go to http://192.168.xxx.xxx:1880/ui/
to get to my NR dashboard
