Very new to NR and not sure how to check this data.
My TV entity ID is simply “media_player.lg_tv” and I want to check this property “source: Streaming Box”.
What kind of node do I use for this and how do I call to check the source property?
Hello smugleafdev,
I do not have a “Smart TV” and I’m not a pro, but maybe I can help you anyway …
I have integrated a Xiaomi Button in HA, in “Developer Tools / Events” can be called by … “Start Listening” the events, the whole looks in my case like this …
(In your case, I would leave the “Events to subscribe” field blank and press the source button “streaming box” on the remote control …)
xiaomi_aqara.click
"click": "single",
"entity_id": "binary_sensor.switch_158d0001e802f9"
The whole thing looks like this …
I eventually figured out the simple solution. I just used a “switch” node with the property set to msg.data.attributes.source == Streaming Box. I used a debug node that spit out the entirety of the data attached to the TV’s current state node, and that’s what tipped me off. A switch node might not be the best, but it works.
