After I do a reboot on my router (unfortunately a daily occurrence) Node Red stops working.
Node red log says:
14 Dec 16:27:46 - [info] [mqtt-broker:MQTT Server] Disconnected from broker: test@mqtt://192.168.1.50:1883
14 Dec 16:28:16 - [info] [mqtt-broker:MQTT Server] Connected to broker: test@mqtt://192.168.1.50:1883
Hassos Log says:
Logger: homeassistant.components.mqtt.client Source: components/mqtt/client.py:748 Integration: MQTT (documentation, issues) First occurred: 4:28:33 PM (1 occurrences) Last logged: 4:28:33 PM No ACK from MQTT server in 10 seconds (mid: 1138)
Even though it looks like it reconnects to the MQTT server, none of the flows will trigger until I do a manual restart of Node Red.
Can anyone else confirm if this is happening for you too?
