Node red entity switch
Dear people, can I switch a switch with an entity in Node Red. I already have the entity button visible and working in the dashboard of Home Asstant. It is not possible to get a switch to work (see photo)
As you can see I am a fairly untrained user :smiley: :smiley:
.Knipsel 1
Use an “events:state” instead of “entity” to flow its state to the next switch (call service).
OK thanks. that works. Now i still have a connecting question. I want to toggle multiple switches with 1 float button in node red.
how could I make that the easiest
Float button? What is that?
You can have multiple lines to switches and from switches.
If the solution was given above, “mark a solution” please.
