Hello
I am asking for help because I do not know how to locate the source of the problem after updating HomeAssistant to version 2024.5.0. I have the following error related to Node-RED in the logs:
Rejestrator: homeassistant.setup
Źródło: setup.py:322
Pierwsze zdarzenie: 18:47:04 (1 zdarzenia)
Ostatnio zalogowany: 18:47:04
Setup failed for custom integration 'nodered': Unable to import component: cannot import name '_get_agent_manager' from 'homeassistant.components.conversation' (/usr/src/homeassistant/homeassistant/components/conversation/__init__.py)
File "/usr/src/homeassistant/homeassistant/loader.py", line 976, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1036, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 144, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/nodered/__init__.py", line 58, in <module>
from .websocket import register_websocket_handlers
File "/config/custom_components/nodered/websocket.py", line 8, in <module>
from homeassistant.components.conversation import (
ImportError: cannot import name '_get_agent_manager' from 'homeassistant.components.conversation' (/usr/src/homeassistant/homeassistant/components/conversation/__init__.py)
File "/usr/src/homeassistant/homeassistant/setup.py", line 322, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 996, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 988, in async_get_component
comp = self._get_component()
