hello i need some support, when i install node red and try to start shows me the next error:
im running on Rasperry Pi 4 Model B
Homeassistant OS
Homeassistant OS
help plis
Go to settings → system → logs. top right hand corner there is a drop down that will have supervisor as an option. Try to install the addon, then go to the above and see what the error is.
Are you able to install other addons?
yes node red its the only that is broken
Go to settings → system → storage. How much disk space is used?
Also, try deleting the add-on and reinstalling it.
Have you restarted Home Assistant after installing the add-on?
