I had no issues with node-red addon until today. I did click the “Update Nodes” button that appeared and that seemed to be ok.
However, although I cannot be certain of timings, it may have been after this that installing nodes from the palette began to fail.
An example (and it is not the only one) is below:
2022-10-22T12:13:48.682Z Install : node-red-contrib-speedtest 1.1.0
2022-10-22T12:13:46.667Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2022-10-22T12:13:48.372Z [err] npm
2022-10-22T12:13:48.373Z [err] WARN
2022-10-22T12:13:48.374Z [err] config production Use `--omit=dev` instead.
2022-10-22T12:14:14.436Z [err] npm WARN deprecated [email protected]: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2022-10-22T12:14:19.985Z [err] npm
2022-10-22T12:14:19.987Z [err]
2022-10-22T12:14:19.989Z [err] ERR!
2022-10-22T12:14:19.990Z [err]
2022-10-22T12:14:19.991Z [err] code
2022-10-22T12:14:19.994Z [err] 1
2022-10-22T12:14:19.996Z [err] npm
2022-10-22T12:14:19.997Z [err]
2022-10-22T12:14:19.997Z [err] ERR!
2022-10-22T12:14:19.998Z [err]
2022-10-22T12:14:19.999Z [err] path
2022-10-22T12:14:19.999Z [err] /config/node-red/node_modules/lzma-native
2022-10-22T12:14:20.030Z [err] npm
2022-10-22T12:14:20.031Z [err]
2022-10-22T12:14:20.032Z [err] ERR!
2022-10-22T12:14:20.032Z [err] command failed
2022-10-22T12:14:20.033Z [err] npm
2022-10-22T12:14:20.034Z [err]
2022-10-22T12:14:20.035Z [err] ERR!
2022-10-22T12:14:20.038Z [err]
2022-10-22T12:14:20.039Z [err] command
2022-10-22T12:14:20.040Z [err] sh -c node-pre-gyp install --fallback-to-build && rimraf build
2022-10-22T12:14:20.042Z [err] npm
2022-10-22T12:14:20.043Z [err]
2022-10-22T12:14:20.044Z [err] ERR!
2022-10-22T12:14:20.045Z [err] Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64/lzma_native.node --module_name=lzma_native --module_path=/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v93 --python=/usr/bin/python3' (1)
2022-10-22T12:14:20.047Z [err] npm
2022-10-22T12:14:20.048Z [err]
2022-10-22T12:14:20.048Z [err] ERR!
2022-10-22T12:14:20.050Z [err] node-pre-gyp info it worked if it ends with ok
2022-10-22T12:14:20.050Z [err] npm ERR! node-pre-gyp info using [email protected]
2022-10-22T12:14:20.050Z [err] npm ERR! node-pre-gyp info using [email protected] | linux | arm64
2022-10-22T12:14:20.052Z [err] npm
2022-10-22T12:14:20.053Z [err] ERR!
2022-10-22T12:14:20.055Z [err] node-pre-gyp WARN Using request for node-pre-gyp https download
2022-10-22T12:14:20.055Z [err] npm ERR! node-pre-gyp info check checked for "/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64/lzma_native.node" (not found)
2022-10-22T12:14:20.055Z [err] npm ERR! node-pre-gyp http GET https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v93-linux-arm64.tar.gz
2022-10-22T12:14:20.055Z [err] npm ERR! node-pre-gyp http 404 https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v93-linux-arm64.tar.gz
2022-10-22T12:14:20.055Z [err] npm ERR! node-pre-gyp WARN Tried to download(404): https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v93-linux-arm64.tar.gz
2022-10-22T12:14:20.055Z [err] npm ERR! node-pre-gyp WARN Pre-built binaries not found for [email protected] and [email protected] (node-v93 ABI, musl) (falling back to source compile with node-gyp)
2022-10-22T12:14:20.055Z [err] npm ERR! node-pre-gyp http 404 status code downloading tarball https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v93-linux-arm64.tar.gz
2022-10-22T12:14:20.055Z [err] npm ERR! gyp info it worked if it ends with ok
2022-10-22T12:14:20.056Z [err] npm ERR! gyp info using [email protected]
2022-10-22T12:14:20.056Z [err] npm ERR! gyp info using [email protected] | linux | arm64
2022-10-22T12:14:20.056Z [err] npm ERR! gyp info ok
2022-10-22T12:14:20.056Z [err] npm ERR! gyp info it worked if it ends with ok
2022-10-22T12:14:20.056Z [err] ERR! gyp ERR! find Python
2022-10-22T12:14:20.056Z [err] npm ERR! gyp ERR! find Python checking Python explicitly set from command line or npm configuration
2022-10-22T12:14:20.057Z [err] ERR! gyp ERR! find Python - "--python=" or "npm config get python" is "/usr/bin/python3"
2022-10-22T12:14:20.057Z [err] npm ERR! gyp ERR! find Python - "/usr/bin/python3" is not in PATH or produced an error
2022-10-22T12:14:20.057Z [err] npm ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
2022-10-22T12:14:20.057Z [err] npm ERR! gyp ERR! find Python checking if "python3" can be used
2022-10-22T12:14:20.057Z [err] ERR! gyp ERR! find Python - "python3" is not in PATH or produced an error
2022-10-22T12:14:20.057Z [err] npm ERR! gyp ERR! find Python checking if "python" can be used
2022-10-22T12:14:20.057Z [err] npm ERR! gyp ERR! find Python - "python" is not in PATH or produced an error
2022-10-22T12:14:20.058Z [err] npm ERR! gyp ERR! find Python **********************************************************
2022-10-22T12:14:20.058Z [err] npm ERR! gyp ERR! find Python You need to install the latest version of Python.
2022-10-22T12:14:20.058Z [err] npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2022-10-22T12:14:20.058Z [err] gyp ERR! find Python you can try one of the following options:
2022-10-22T12:14:20.058Z [err] npm ERR! gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"
2022-10-22T12:14:20.058Z [err] npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)
2022-10-22T12:14:20.058Z [err] npm ERR! gyp ERR! find Python - Set the environment variable PYTHON
2022-10-22T12:14:20.059Z [err] ERR! gyp ERR! find Python - Set the npm configuration variable python:
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! find Python npm config set python "/path/to/pythonexecutable"
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! find Python For more information consult the documentation at:
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! find Python **********************************************************
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! configure error
2022-10-22T12:14:20.059Z [err] ERR! gyp ERR! stack Error: Could not find any Python installation to use
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! stack at PythonFinder.fail (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:330:47)
2022-10-22T12:14:20.059Z [err] npm ERR! gyp ERR! stack at PythonFinder.runChecks (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:159:21)
2022-10-22T12:14:20.060Z [err] gyp ERR! stack at PythonFinder.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:202:16)
2022-10-22T12:14:20.060Z [err] npm ERR! gyp ERR! stack at PythonFinder.execFileCallback (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:294:16)
2022-10-22T12:14:20.060Z [err] npm ERR! gyp ERR! stack at exithandler (node:child_process:406:5)
2022-10-22T12:14:20.060Z [err] npm ERR! gyp ERR! stack at ChildProcess.errorhandler (node:child_process:418:5)
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:527:28)
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:289:12)
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! stack at onErrorNT (node:internal/child_process:478:16)
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! stack at processTicksAndRejections (node:internal/process/task_queues:83:21)
2022-10-22T12:14:20.061Z [err] ERR! gyp ERR! System Linux 5.15.61-v8
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64/lzma_native.node" "--module_name=lzma_native" "--module_path=/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v93" "--python=/usr/bin/python3"
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! cwd /config/node-red/node_modules/lzma-native
2022-10-22T12:14:20.061Z [err] gyp ERR! node -v v16.16.0
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! node-gyp -v v9.0.0
2022-10-22T12:14:20.061Z [err] npm ERR! gyp ERR! not ok
2022-10-22T12:14:20.061Z [err] npm ERR! node-pre-gyp ERR! build error
2022-10-22T12:14:20.062Z [err] ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64/lzma_native.node --module_name=lzma_native --module_path=/config/node-red/node_modules/lzma-native/binding-v4.0.6-node-v93-linux-arm64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v93 --python=/usr/bin/python3' (1)
2022-10-22T12:14:20.062Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/config/node-red/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
2022-10-22T12:14:20.062Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.emit (node:events:527:28)
2022-10-22T12:14:20.062Z [err] node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1092:16)
2022-10-22T12:14:20.062Z [err] npm ERR! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
2022-10-22T12:14:20.062Z [err] npm ERR! node-pre-gyp ERR! System Linux 5.15.61-v8
2022-10-22T12:14:20.062Z [err] npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/config/node-red/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
2022-10-22T12:14:20.063Z [err] node-pre-gyp ERR! cwd /config/node-red/node_modules/lzma-native
2022-10-22T12:14:20.063Z [err] npm ERR! node-pre-gyp ERR! node -v v16.16.0
2022-10-22T12:14:20.063Z [err] npm ERR! node-pre-gyp ERR! node-pre-gyp -v v0.11.0
2022-10-22T12:14:20.063Z [err] node-pre-gyp ERR! not ok
2022-10-22T12:14:20.075Z [err]
2022-10-22T12:14:20.076Z [err] npm ERR! A complete log of this run can be found in:
2022-10-22T12:14:20.077Z [err] npm ERR! /root/.npm/_logs/2022-10-22T12_13_48_228Z-debug-0.log
2022-10-22T12:14:20.124Z rc=1
Not sure what to do. I am unsure about re-installing, even though I know export should save all my flows. However, I have created a lot of flows already, many working with installed nodes, and my concern is that a re-install may result in these working nodes failing to install, thus breaking all my current flows that work.
I have restarted Node Red but installs still fail.
Any help appreciated.
