Dear Home Assistant users,
I’m a newbee using this platform and that also includes using Node Red as a flow tool.
My old platform was Domoticz including the Blockly scripts (easy: If, then, else, endif statements/like a puzzle).
At the time of writing I’m trying to use Red Node to:
- Enable the motion detector after the sunset and turn the light on for 1 minute (when motion is detected).
- Disable the motion detector when the sun rises again (otherwise it doesnt make much sense → lights on when the sun shines
This was quite easy in Domoticz, but I’m strugling to get this working in Node Red.
Is there a (simple/not too complex) template available as an example (nothing more or less)?
Thank you in advance for an answer ![]()
