Without going into too much depth I am attempting to convert a Template to a TTS message.
But I am unable to get the json format to understand the payload.
Can anyone give the correct format? I am assuming a function here but by coding is abysmal.
Hans
Happy New Year!
NB
This is part of this flow. Im tryting to get a notification on when I set my alarm that a door/window is open. I want Alexa to tell me which door it is.
Also you’re using web socket for homeassistant so you can also now render the template in the call service node without the classic nodered template, using the same mustache syntax just make sure you mark the checkbox.
Can you show me how you have configured each nodes? i’m trying to do the same without results.
I have configured the flow in the same way, if i start flow with inject node everything work fine with trigger state i don’t get notification even if the debug result is the same
