This use to work for me in a function node in Node Red, but no longer gets the state information.
msg.payload =
"The temperature is "+
“{{states.sensor.house_temperature.state}}”
return msg
msg.payload =
return msg
Please use code tags.
Can you see the sensor state in developer tools → states?
Yes, I can see the sensor state in developer tools → states.
The output is The temperature is {{states.sensor.house_temperature.state}}
It does not place the actual state in the sentence
That’s actually a Jinja2 template, and it would never have been rendered directly in a function node. If you were passing it to a call-service
node, then Home Assistant would have processed the Jinja2 template on its side. However, if this was used with a notification service, Home Assistant recently removed the ability for notification services to render Jinja2 templates.
You can achieve similar functionality by using Node-RED to generate the message instead and passing the final text directly to Home Assistant.
I am using the function node with “Amazon Echo Hub” to announce on an echo speaker. This worked fine for years, I just noticed it recently it’s not working but I hadn’t used it for a while.
The equivalent of
in jsonata is
$entities('sensor.house_temperature').state
Thank you for giving the jasonata equivalent but I don’t have much of an idea how to make this work. Can you please explain how I could make this work for what I am trying to do.
