Node-RED: Get-Entities in Group = Labels, HA Helper Group or what is it?
It is not clear for me what is meant with the search option “in group” and the suggested answer group.group_name. The documentation does not even contain the string group. I could not find any documentation regarding that.
Is a group referenced as a label in Home Assistant or is it the Home Assistant Helper Group introduced in 2022.4?
If it’s the label, do i have to label the device or the entity i want to control?
It is for ha groups.
What are ha groups? I found several documentation, which one are you referring to?
The group entity, your first link.
Thank you for providing this information.
I have setup a group in Home Assistant:
And setup the get entities node, regardless if i use group.alarm or alarm i am not getting the entities.
Any hints?
Double check your group name. It should start with the domain(light, sensor, etc) of the group and not group.
That have done the job, thank you.
