Node-Red giving a black screen
I made a HA installation by following this https://github.com/tirtadji-com/rpi_debian_ha_supervised. It is a great tutorial made by Richard Tirtadji!!
I installed the following addons: VSCode, Mosquitto broker, and Node-Red.
Node-Red with the following configuration:
With the following config:
credential_secret: *******
dark_mode: false
http_node:
  username: ''
  password: ''
http_static:
  username: ''
  password: ''
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
require_ssl: false
system_packages: []
npm_packages: []
init_commands: []
Unfortunately, when clicking on the Node-Red button (after starting) on the left I only get a black screen.
I don’t get specific errors but two warnings
[warn] [RED.events] Deprecated use of "nodes-started" event from "/opt/node_modules/node-red-contrib-actionflows/actionflows/actionflows.js:615:14". Use "flows:started" instead.
[warn] Projects disabled : editorTheme.projects.enabled=false
Configuration > Server Controles > Check configuration gives Configuration Valid
I’m just starting with HA. But hopefully, there is someone who can help to get Node-Red working?
Looking forward to hearing from you,
Kind regard,
Robert
The hardware I installed on is an RPi4 4Gb and an SSD. with Home Assistant 2021.1.5
I did a complete reinstall. Now it is working. Possible error could be that I put an user name and password in the config files of Node-Red.
