Node red GUI choppy/laggy
HA “Blue” hardware
Latest HA version.
My unit is hardwired.
Tried rebooting.
No other part of the HA interface is slow.
Video below. its just very choppy. Is this just because of all the tabs aka flows I have? ( I have 23 tabs)
What’s going on in HA and nodered logs?
Heres nodered logs. Which HA log would you like? (supervisor, host, core, etc)?
2 Oct 08:01:17 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:17 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:17 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:23 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:23 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:23 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:23 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:28 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:28 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:28 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:28 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:33 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:33 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:33 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:33 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:38 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:38 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:38 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:38 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:43 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:43 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:43 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:43 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:48 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:48 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:48 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:53 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:53 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:53 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:01:59 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:01:59 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:01:59 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:01:59 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:02:04 - [info] [server:AvilaSmartHomeRpi] Connecting to http://supervisor/core
2 Oct 08:02:04 - [info] [server:Home Assistant] Connecting to http://supervisor/core
2 Oct 08:02:04 - [info] [server:Home Assistant] Connected to http://supervisor/core
2 Oct 08:02:04 - [info] [server:AvilaSmartHomeRpi] Connected to http://supervisor/core
2 Oct 08:02:04 - [info] [server:Home Assistant] Connecting to undefined
2 Oct 08:02:04 - [info] [server:AvilaSmartHome] Connecting to http://supervisor/core
2 Oct 08:02:04 - [info] [server:Home Assistant] Connected to undefined
2 Oct 08:02:05 - [info] [server:AvilaSmartHome] Connected to http://supervisor/core
2 Oct 08:02:13 - [warn] [alexa-remote-account:f0ce5fbc.18734] failed to load routines: "no body"
2 Oct 18:55:25 - [info] Stopping modified nodes
2 Oct 18:55:25 - [info] Stopped modified nodes
2 Oct 18:55:25 - [info] Starting modified nodes
2 Oct 18:55:25 - [info] Started modified nodes
2 Oct 19:02:28 - [info] Stopping modified nodes
2 Oct 19:02:28 - [info] Stopped modified nodes
2 Oct 19:02:28 - [info] Starting modified nodes
2 Oct 19:02:28 - [info] Started modified nodes
2 Oct 19:03:27 - [info] Stopping modified nodes
2 Oct 19:03:27 - [info] Stopped modified nodes
2 Oct 19:03:27 - [info] Starting modified nodes
2 Oct 19:03:27 - [info] Started modified nodes
Well there you go, you have a web socket error. Look at the ha server drop down list in a call service, is there more than one server entry? First remove any copies, if it persists remove and reinstall usually works. Don’t forget to backup first.
@Mikefila
First off;
Second off,
What exactly did you see to say I had a websocket error? The “connecting to undefined” lines?
More so the amount of attempts to connect. It’s usually once and then it connects.
