Hi all, and thanks in advance, as usual.
I’m running Node-RED in a Docker container (alongside unifi, ha, letsencrypt, and portainer). HA is at 0.94.0 and works great.
Yesterday, I updated node-red-contrib-home-assistant-websocket to 0.12.3 from 0.11.0 (I’m about 75% sure this was the version I was at). After doing so, without changing anything else, suddenly all of my HA nodes show “disconnected” or “no connection”. I did not change the HA server node base URL or access token.
So far, I’ve tried restarting my Node-RED and HA containers (multiple times, in every possible order) and creating a new access token, neither of which helped.
To be clear, I don’t get the big error that says “Lost connection to server, reconnecting…” which appears when you have the wrong HA URL or port.
Anyone have any thoughts?
