I’m still learning as well but I have an alternative solution for your first question using the big timer node:
[{"id":"4df685db.b408fc","type":"subflow","name":"Security Lights On","info":"","category":"","in":[{"x":20,"y":80,"wires":[{"id":"db877ee7.4b219"},{"id":"6331b553.35c13c"}]}],"out":[{"x":400,"y":60,"wires":[{"id":"db877ee7.4b219","port":0},{"id":"6331b553.35c13c","port":0}]}],"env":[],"status":{"x":400,"y":160,"wires":[{"id":"db877ee7.4b219","port":0},{"id":"6331b553.35c13c","port":0}]}},{"id":"db877ee7.4b219","type":"api-call-service","z":"4df685db.b408fc","name":"Coach lights on (25%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.coach","data":"{\"transition\":3,\"brightness_pct\":25}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":200,"y":80,"wires":[[]]},{"id":"6331b553.35c13c","type":"api-call-service","z":"4df685db.b408fc","name":"Lanai lights on (10%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.lanai","data":"{\"transition\":3,\"brightness_pct\":10}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":200,"y":140,"wires":[[]]},{"id":"583b5c28.942304","type":"subflow","name":"Lanai, Coach, Entryway lights off?","info":"","category":"","in":[{"x":240,"y":240,"wires":[{"id":"126cbf5f.894661"},{"id":"e51a6444.ab76a8"},{"id":"b1150990.a46b88"}]}],"out":[{"x":640,"y":240,"wires":[{"id":"e51a6444.ab76a8","port":1},{"id":"126cbf5f.894661","port":1},{"id":"b1150990.a46b88","port":1}]}],"env":[]},{"id":"e51a6444.ab76a8","type":"api-current-state","z":"583b5c28.942304","name":"Coach lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.coach","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":450,"y":180,"wires":[[],[]]},{"id":"126cbf5f.894661","type":"api-current-state","z":"583b5c28.942304","name":"Lanai lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lanai","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":440,"y":220,"wires":[[],[]]},{"id":"b1150990.a46b88","type":"api-current-state","z":"583b5c28.942304","name":"Entryway lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.entryway","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":450,"y":260,"wires":[[],[]]},{"id":"6d01bd69.eb5cf4","type":"switch","z":"fdebb431.1a00e8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":270,"y":120,"wires":[["52506023.4d3b2"],["d5d2f818.742148","5f2e4717.fe8078","713917ae.0b1918"]]},{"id":"d5d2f818.742148","type":"api-current-state","z":"fdebb431.1a00e8","name":"Lanai lights on?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lanai","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":420,"y":180,"wires":[["8579f348.d48ac"],[]]},{"id":"5f2e4717.fe8078","type":"api-current-state","z":"fdebb431.1a00e8","name":"Coach lights on?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.coach","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":430,"y":240,"wires":[["73361147.5bc23"],[]]},{"id":"512a706b.d48e2","type":"api-call-service","z":"fdebb431.1a00e8","name":"Lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.lanai, light.coach, light.entryway, light.dining","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":860,"y":300,"wires":[["91cae457.31d5c8"]]},{"id":"da4fc58.6a54638","type":"bigtimer","z":"fdebb431.1a00e8","outtopic":"","outpayload1":"","outpayload2":"","name":"Sunrise - Sunset","comment":"","lat":"27.918805","lon":"-81.866830","starttime":"5004","endtime":"5003","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"on","outtext2":"off","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"repeat":true,"atstart":false,"odd":false,"even":false,"x":110,"y":80,"wires":[[],[],["6d01bd69.eb5cf4"]]},{"id":"b2decf80.da593","type":"inject","z":"fdebb431.1a00e8","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":140,"wires":[["6d01bd69.eb5cf4"]]},{"id":"8579f348.d48ac","type":"api-call-service","z":"fdebb431.1a00e8","name":"Lanai Lights on (100%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.lanai","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":630,"y":180,"wires":[["512a706b.d48e2"]]},{"id":"73361147.5bc23","type":"api-call-service","z":"fdebb431.1a00e8","name":"Coach Lights on (100%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.coach","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":650,"y":240,"wires":[["512a706b.d48e2"]]},{"id":"f8d9e5e.8768d18","type":"inject","z":"fdebb431.1a00e8","name":"","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":180,"wires":[["6d01bd69.eb5cf4"]]},{"id":"713917ae.0b1918","type":"api-call-service","z":"fdebb431.1a00e8","name":"Entryway Lights on (100%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.entryway","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":460,"y":300,"wires":[["512a706b.d48e2"]]},{"id":"5bb2ac7f.f822b4","type":"comment","z":"fdebb431.1a00e8","name":"At sunrise, set brightness to 100% and turn everything off.","info":"","x":550,"y":140,"wires":[]},{"id":"c0803698.46ae78","type":"comment","z":"fdebb431.1a00e8","name":"Turn on the Coach and Lanai lights at sunset, and set brightness to 25%.","info":"","x":600,"y":40,"wires":[]},{"id":"91cae457.31d5c8","type":"delay","z":"fdebb431.1a00e8","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":990,"y":300,"wires":[["58fb4338.5712ac"]]},{"id":"58fb4338.5712ac","type":"subflow:583b5c28.942304","z":"fdebb431.1a00e8","name":"","env":[],"x":1220,"y":300,"wires":[["8bc5c11f.06689"]]},{"id":"8bc5c11f.06689","type":"api-call-service","z":"fdebb431.1a00e8","name":"Lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.lanai, light.coach, light.entryway, light.dining","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1440,"y":300,"wires":[["58fb4338.5712ac"]]},{"id":"8dd4e4dc.03cfc8","type":"api-current-state","z":"fdebb431.1a00e8","name":"Security lights on?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.entryway","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":770,"y":80,"wires":[[],["570e86f5.22abd8"]]},{"id":"52506023.4d3b2","type":"subflow:4df685db.b408fc","z":"fdebb431.1a00e8","name":"Security Lights On","env":[],"x":450,"y":80,"wires":[["a61291cc.88e85"]]},{"id":"570e86f5.22abd8","type":"subflow:4df685db.b408fc","z":"fdebb431.1a00e8","name":"Security Lights On","env":[],"x":970,"y":80,"wires":[[]]},{"id":"a61291cc.88e85","type":"delay","z":"fdebb431.1a00e8","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":610,"y":80,"wires":[["8dd4e4dc.03cfc8"]]},{"id":"26956a45.92d866","type":"server","z":"","name":"Hass.io","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
To your second question, and I know there’s a better way to do this but a “current state” node will help. It’s basically; “is this already on? Yes - then do this. No - then do this”.
There are three of them in the flow I posted above, they should be able to show you how to use them.
I misread your second question. In your “over 80?” state node, is “Output only on state change” checked or unchecked?
