Node-Red: Help with radiator automation
Hi!
I set up something which should set the temperature of several radiators in different rooms based on presence and time in node-red:
[{"id":"2f5951b90e8bf17c","type":"tab","label":"Heating","disabled":false,"info":""},{"id":"b6a4d59abb2b1c54","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Temperature | Hannahs Room","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_hannahs_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2000,"y":360,"wires":[[]]},{"id":"afe5bbbbefe72746","type":"light-scheduler","z":"2f5951b90e8bf17c","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}}]","topic":"","name":"Day / Night Kids","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1340,"y":80,"wires":[["f2c07e85a9602f34","25bdfc68ce5d4d36"]]},{"id":"726460e9362826e4","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Temperature | Lenas Room","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_lenas_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1990,"y":420,"wires":[[]]},{"id":"7c1be1ae114c9ea1","type":"light-scheduler","z":"2f5951b90e8bf17c","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Day / Night Sleeping Room","onPayload":"on","onPayloadType":"str","offPayload":"off","offPayloadType":"str","onlyWhenDark":true,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1380,"y":200,"wires":[["cf1ac6da90653b20"]]},{"id":"e3cb7a5a7cb3e6f1","type":"light-scheduler","z":"2f5951b90e8bf17c","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":540}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":540}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":540}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":540}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":540}},{\"start\":{\"dow\":6,\"mod\":420},\"end\":{\"dow\":6,\"mod\":600}},{\"start\":{\"dow\":0,\"mod\":420},\"end\":{\"dow\":0,\"mod\":600}}]","topic":"","name":"Day / Night Bath Room","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1360,"y":360,"wires":[["ef1dbafdfce5380a"]]},{"id":"0d7fc4b8b2298325","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Temperature | Bath Room","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_badezimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2270,"y":720,"wires":[[]]},{"id":"ad3392185714df29","type":"light-scheduler","z":"2f5951b90e8bf17c","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1380}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1380}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1380}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1380}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1380}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1380}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1380}}]","topic":"","name":"Day / Night Living Room","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1370,"y":460,"wires":[["9c62182bd7cafdc2"]]},{"id":"a05ba9c46ff889cc","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Temperature | Living Room","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.temperatur_wohnzimmer","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2090,"y":840,"wires":[["b54a5fc7612d8bfb"]]},{"id":"cf1ac6da90653b20","type":"switch","z":"2f5951b90e8bf17c","name":"Heat Yes/No","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1620,"y":180,"wires":[["94a047a9dbfe1ed9"],["c641fb4aac494fe3"]]},{"id":"b08ebe5492c3108d","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Temperature | Sleeping Room","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_schlafzimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2480,"y":560,"wires":[["7740bd0362e31ac1"]]},{"id":"94a047a9dbfe1ed9","type":"light-scheduler","z":"2f5951b90e8bf17c","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":1285},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":1285},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":1285},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":1285},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":1285},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":1285},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":1285},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Normal or Evening Boost","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.minutely","x":1830,"y":160,"wires":[["01cea63e197f303b","448f606b8919224e"]]},{"id":"c6534c87680a2284","type":"switch","z":"2f5951b90e8bf17c","name":"Set Heating Path","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Away","vt":"str"},{"t":"eq","v":"Vacation","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":780,"wires":[["46dd4eef64bc7893"],["9ef1bc05ee5de5c6"]]},{"id":"c641fb4aac494fe3","type":"change","z":"2f5951b90e8bf17c","name":"Set to Night Temperature","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1830,"y":220,"wires":[["01cea63e197f303b"]]},{"id":"46dd4eef64bc7893","type":"change","z":"2f5951b90e8bf17c","name":"Set msg.payload to 18","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":780,"wires":[["b6a4d59abb2b1c54","726460e9362826e4","b08ebe5492c3108d","0d7fc4b8b2298325","a05ba9c46ff889cc"]]},{"id":"bfc1c0b9302a7d7b","type":"server-state-changed","z":"2f5951b90e8bf17c","name":"","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.family","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":160,"y":560,"wires":[["c5ab0a1162a6a90e"]]},{"id":"47be45a3edad054a","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Heating Mode Home","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Home\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":730,"y":360,"wires":[[]]},{"id":"67c960fba9e4939e","type":"switch","z":"2f5951b90e8bf17c","name":"Set Heating Mode","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"home","vt":"str"},{"t":"eq","v":"not_home","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":450,"y":420,"wires":[["47be45a3edad054a"],["f0f328eeaa5acb16"]]},{"id":"f0f328eeaa5acb16","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Heating Mode Away","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Away\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":730,"y":440,"wires":[[]]},{"id":"c5ab0a1162a6a90e","type":"api-current-state","z":"2f5951b90e8bf17c","name":"Heating in Holiday Mode?","server":"aadbde09.d5ab3","version":2,"outputs":2,"halt_if":"Holiday","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"input_select.heating","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":560,"wires":[["67c960fba9e4939e"],[]]},{"id":"9ef1bc05ee5de5c6","type":"change","z":"2f5951b90e8bf17c","name":"Set msg.payload to 15","rules":[{"t":"set","p":"payload","pt":"msg","to":"15","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":880,"wires":[["b6a4d59abb2b1c54","726460e9362826e4","b08ebe5492c3108d","0d7fc4b8b2298325","a05ba9c46ff889cc"]]},{"id":"5ab28801c6de856a","type":"server-state-changed","z":"2f5951b90e8bf17c","name":"Heating Mode Changed","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":240,"y":780,"wires":[["723b0bd26bf8a31c"]]},{"id":"723b0bd26bf8a31c","type":"rbe","z":"2f5951b90e8bf17c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":470,"y":780,"wires":[["c6534c87680a2284"]]},{"id":"2478bbf9b6667f57","type":"api-current-state","z":"2f5951b90e8bf17c","name":"Heating Status = Home","server":"aadbde09.d5ab3","version":2,"outputs":2,"halt_if":"Home","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.heating","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":690,"y":680,"wires":[["a716e8d62405f657"],["297a6a792310462a"]]},{"id":"a716e8d62405f657","type":"change","z":"2f5951b90e8bf17c","name":"Set msg.payload to schedule-only","rules":[{"t":"set","p":"payload","pt":"msg","to":"schedule-only","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":640,"wires":[["afe5bbbbefe72746","7c1be1ae114c9ea1","e3cb7a5a7cb3e6f1","ad3392185714df29"]]},{"id":"721183cd349744cb","type":"inject","z":"2f5951b90e8bf17c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"1","topic":"","payloadType":"date","x":470,"y":680,"wires":[["2478bbf9b6667f57"]]},{"id":"01cea63e197f303b","type":"rbe","z":"2f5951b90e8bf17c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":2050,"y":200,"wires":[["b08ebe5492c3108d"]]},{"id":"f2c07e85a9602f34","type":"rbe","z":"2f5951b90e8bf17c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1510,"y":40,"wires":[["b6a4d59abb2b1c54"]]},{"id":"9c62182bd7cafdc2","type":"rbe","z":"2f5951b90e8bf17c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1570,"y":460,"wires":[["a05ba9c46ff889cc"]]},{"id":"25bdfc68ce5d4d36","type":"rbe","z":"2f5951b90e8bf17c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1500,"y":100,"wires":[["726460e9362826e4"]]},{"id":"b54a5fc7612d8bfb","type":"api-call-service","z":"2f5951b90e8bf17c","name":"Set Temperature | Main Heating","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.zentralheizung","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2410,"y":840,"wires":[[]]},{"id":"ef1dbafdfce5380a","type":"rbe","z":"2f5951b90e8bf17c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1650,"y":360,"wires":[["0d7fc4b8b2298325"]]},{"id":"297a6a792310462a","type":"change","z":"2f5951b90e8bf17c","name":"Set msg.payload to stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":680,"wires":[["afe5bbbbefe72746","7c1be1ae114c9ea1","e3cb7a5a7cb3e6f1","ad3392185714df29"]]},{"id":"7740bd0362e31ac1","type":"debug","z":"2f5951b90e8bf17c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2800,"y":560,"wires":[]},{"id":"448f606b8919224e","type":"debug","z":"2f5951b90e8bf17c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2130,"y":100,"wires":[]},{"id":"aadbde09.d5ab3","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"f50788c8abb772f2","type":"light-scheduler-settings","name":"Home","latitude":"48.100645","longitude":"16.305638"}]
The thing is, for the part where mode = Home, I can not set the temperature only if it changes.
Currently I’m using the rbe filter but this does not work here.
If I switch from Home to Away and the back to Home, while the Light Schedulers didn’t change their output, the temperature will not be set.
How can I make the home assistant values change, only if they don’t have the same value at the moment?
Thanks!
I think I’m getting where it should be.
[{"id":"a57e661709f9b8e3","type":"tab","label":"Heating","disabled":false,"info":""},{"id":"437c14d860a5b12b","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Temperature | Hannahs Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_hannahs_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2000,"y":360,"wires":[[]]},{"id":"559ebb3e764a15fd","type":"light-scheduler","z":"a57e661709f9b8e3","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}}]","topic":"","name":"Day / Night Kids","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1340,"y":80,"wires":[["d9af662e3315cca7","6c1001377e4bdbe0"]]},{"id":"74bbc957609c709e","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Temperature | Lenas Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_lenas_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1990,"y":420,"wires":[[]]},{"id":"827cb2bfefb3c471","type":"light-scheduler","z":"a57e661709f9b8e3","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Day / Night Sleeping Room","onPayload":"on","onPayloadType":"str","offPayload":"off","offPayloadType":"str","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1380,"y":200,"wires":[["efd0fbb63a2c7e7f"]]},{"id":"9e64f34c8ca4c4ac","type":"light-scheduler","z":"a57e661709f9b8e3","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":540}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":540}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":540}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":540}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":540}},{\"start\":{\"dow\":6,\"mod\":420},\"end\":{\"dow\":6,\"mod\":600}},{\"start\":{\"dow\":0,\"mod\":420},\"end\":{\"dow\":0,\"mod\":600}}]","topic":"","name":"Day / Night Bath Room","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1360,"y":360,"wires":[["5f8c0819f878b164"]]},{"id":"a2f3971f0b1cda76","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Temperature | Bath Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_badezimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2270,"y":720,"wires":[[]]},{"id":"089305f8ba4d2c08","type":"light-scheduler","z":"a57e661709f9b8e3","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1380}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1380}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1380}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1380}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1380}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1380}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1380}}]","topic":"","name":"Day / Night Living Room","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1370,"y":460,"wires":[["a956418ecea03caa"]]},{"id":"7c4230505249c8ef","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Temperature | Living Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.temperatur_wohnzimmer","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2070,"y":860,"wires":[["ad4143b6ab2c0286"]]},{"id":"efd0fbb63a2c7e7f","type":"switch","z":"a57e661709f9b8e3","name":"Heat Yes/No","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1620,"y":180,"wires":[["67689040b7ec11aa"],["2c54e533ac82a99b"]]},{"id":"b146f8f6e4609867","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Temperature | Sleeping Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_schlafzimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2480,"y":560,"wires":[[]]},{"id":"67689040b7ec11aa","type":"light-scheduler","z":"a57e661709f9b8e3","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":1285},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":1285},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":1285},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":1285},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":1285},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":1285},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":1285},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Normal or Evening Boost","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.minutely","x":1830,"y":160,"wires":[["e88dfad5da561c67"]]},{"id":"c29f157586927e90","type":"switch","z":"a57e661709f9b8e3","name":"Set Heating Path","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Away","vt":"str"},{"t":"eq","v":"Vacation","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":780,"wires":[["9fd2304b9bd536ed"],["f514b59f427d69c7"]]},{"id":"2c54e533ac82a99b","type":"change","z":"a57e661709f9b8e3","name":"Set to Night Temperature","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1830,"y":220,"wires":[["e88dfad5da561c67"]]},{"id":"9fd2304b9bd536ed","type":"change","z":"a57e661709f9b8e3","name":"Set msg.payload to 18","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":780,"wires":[["437c14d860a5b12b","74bbc957609c709e","b146f8f6e4609867","a2f3971f0b1cda76","7c4230505249c8ef"]]},{"id":"2b71d688cd84d780","type":"server-state-changed","z":"a57e661709f9b8e3","name":"","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.family","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":160,"y":560,"wires":[["4299ade84d82e03f"]]},{"id":"7356aa7d4141d119","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Heating Mode Home","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Home\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":730,"y":360,"wires":[[]]},{"id":"7576537370f21450","type":"switch","z":"a57e661709f9b8e3","name":"Set Heating Mode","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"home","vt":"str"},{"t":"eq","v":"not_home","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":450,"y":420,"wires":[["7356aa7d4141d119"],["8471a204f02482df"]]},{"id":"8471a204f02482df","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Heating Mode Away","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Away\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":730,"y":440,"wires":[[]]},{"id":"4299ade84d82e03f","type":"api-current-state","z":"a57e661709f9b8e3","name":"Heating in Holiday Mode?","server":"aadbde09.d5ab3","version":2,"outputs":2,"halt_if":"Holiday","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"input_select.heating","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":560,"wires":[["7576537370f21450"],[]]},{"id":"f514b59f427d69c7","type":"change","z":"a57e661709f9b8e3","name":"Set msg.payload to 15","rules":[{"t":"set","p":"payload","pt":"msg","to":"15","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":880,"wires":[["437c14d860a5b12b","74bbc957609c709e","b146f8f6e4609867","a2f3971f0b1cda76","7c4230505249c8ef"]]},{"id":"5bca0f75af06eff4","type":"server-state-changed","z":"a57e661709f9b8e3","name":"Heating Mode Changed","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":240,"y":780,"wires":[["37c48daaec99834c"]]},{"id":"37c48daaec99834c","type":"rbe","z":"a57e661709f9b8e3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":470,"y":780,"wires":[["c29f157586927e90"]]},{"id":"aa8b21bd99be9a9c","type":"api-current-state","z":"a57e661709f9b8e3","name":"Heating Status = Home","server":"aadbde09.d5ab3","version":2,"outputs":2,"halt_if":"Home","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.heating","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":690,"y":680,"wires":[["8a8b8be843b6a5a5"],["f512d06d07116a73"]]},{"id":"8a49c50b10a583b3","type":"inject","z":"a57e661709f9b8e3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"1","topic":"","payloadType":"date","x":470,"y":680,"wires":[["aa8b21bd99be9a9c"]]},{"id":"e88dfad5da561c67","type":"rbe","z":"a57e661709f9b8e3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":2050,"y":200,"wires":[["b146f8f6e4609867"]]},{"id":"d9af662e3315cca7","type":"rbe","z":"a57e661709f9b8e3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1510,"y":40,"wires":[["437c14d860a5b12b"]]},{"id":"a956418ecea03caa","type":"rbe","z":"a57e661709f9b8e3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1570,"y":460,"wires":[["7c4230505249c8ef"]]},{"id":"6c1001377e4bdbe0","type":"rbe","z":"a57e661709f9b8e3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1500,"y":100,"wires":[["74bbc957609c709e"]]},{"id":"ad4143b6ab2c0286","type":"api-call-service","z":"a57e661709f9b8e3","name":"Set Temperature | Main Heating","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.zentralheizung","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2410,"y":840,"wires":[[]]},{"id":"8a8b8be843b6a5a5","type":"change","z":"a57e661709f9b8e3","name":"Set msg.payload to triggered once","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":600,"wires":[["559ebb3e764a15fd","827cb2bfefb3c471","9e64f34c8ca4c4ac","089305f8ba4d2c08"]]},{"id":"f512d06d07116a73","type":"change","z":"a57e661709f9b8e3","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":660,"wires":[["5f8c0819f878b164","a956418ecea03caa","e88dfad5da561c67","6c1001377e4bdbe0","d9af662e3315cca7"]]},{"id":"5f8c0819f878b164","type":"rbe","z":"a57e661709f9b8e3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1590,"y":360,"wires":[["a2f3971f0b1cda76"]]},{"id":"aadbde09.d5ab3","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"f50788c8abb772f2","type":"light-scheduler-settings","name":"Home","latitude":"48.100645","longitude":"16.305638"}]
Added a state which triggers the light schedules once and one which resets the filter everytime the mode changes to anything else then “Home”
The filter after the event state is not needed it will only output on state change. Speaking of, why are you checking the heating status state every 10 seconds? An event state node will output when the heating state changes, it’s not necessary to constantly check.
Thanks for your reply.
I run the Home part each 10 seconds since I don’t want to run the temperature settings in the process only once.
Or do I understand the Light Schedule wrong, so it will also run afterwards even the heating mode didn’t change anymore?
When you give it any input(override), it comes out of auto mode and is only re-enabled by sending auto. It’s default is auto. There is also the output make sure it set, then it will output based on schedule.
That’s the thing I want to achieve with the 10 seconds (could also be like 1 minute): to re-run the light schedule.
So I don’t think I can just change this for the state event trigger or am I wrong with that?
Ah so what you mean is, that with auto mode, it does not need any further input to run?
So I removed the 10 min interval, changed to events: state and removed the filters:
[{"id":"f1fbd0e36d0809e6","type":"tab","label":"Heating 2","disabled":false,"info":""},{"id":"a8d97d4fe395a4aa","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Hannahs Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_hannahs_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2000,"y":360,"wires":[[]]},{"id":"92c6a75428833a41","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}}]","topic":"","name":"Day / Night Kids","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1340,"y":80,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f"]]},{"id":"7791bcc7a4b7ad8f","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Lenas Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_lenas_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1990,"y":420,"wires":[["5c08655e39db6440"]]},{"id":"56b8b37c133a2748","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Day / Night Sleeping Room","onPayload":"on","onPayloadType":"str","offPayload":"off","offPayloadType":"str","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1380,"y":200,"wires":[["04ee1386bc0ab20b"]]},{"id":"9f02e0b69803c80b","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":540}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":540}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":540}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":540}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":540}},{\"start\":{\"dow\":6,\"mod\":420},\"end\":{\"dow\":6,\"mod\":600}},{\"start\":{\"dow\":0,\"mod\":420},\"end\":{\"dow\":0,\"mod\":600}}]","topic":"","name":"Day / Night Bath Room","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1360,"y":360,"wires":[["c3f778f6bc7085f3"]]},{"id":"c3f778f6bc7085f3","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Bath Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_badezimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2270,"y":720,"wires":[[]]},{"id":"adb4d1901d14482f","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1380}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1380}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1380}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1380}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1380}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1380}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1380}}]","topic":"","name":"Day / Night Living Room","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1370,"y":460,"wires":[["f3dde576849f5a31"]]},{"id":"f3dde576849f5a31","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Living Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.temperatur_wohnzimmer","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2070,"y":860,"wires":[["3a007527920cac82"]]},{"id":"04ee1386bc0ab20b","type":"switch","z":"f1fbd0e36d0809e6","name":"Heat Yes/No","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1620,"y":180,"wires":[["31ac6e26b4de07d2"],["9cac579858ef364f"]]},{"id":"d6e05d4c270fa284","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Sleeping Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_schlafzimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2480,"y":560,"wires":[[]]},{"id":"31ac6e26b4de07d2","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":1285},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":1285},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":1285},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":1285},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":1285},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":1285},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":1285},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Normal or Evening Boost","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1830,"y":160,"wires":[["d6e05d4c270fa284"]]},{"id":"2850f34bfe231fb3","type":"switch","z":"f1fbd0e36d0809e6","name":"Set Heating Path","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Away","vt":"str"},{"t":"eq","v":"Vacation","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":780,"wires":[["ca332450895580ef"],["0f46223f038b8ffe"]]},{"id":"9cac579858ef364f","type":"change","z":"f1fbd0e36d0809e6","name":"Set to Night Temperature","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1830,"y":220,"wires":[["d6e05d4c270fa284"]]},{"id":"ca332450895580ef","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to 18","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":780,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f","d6e05d4c270fa284","c3f778f6bc7085f3","f3dde576849f5a31"]]},{"id":"9121355fb43bb4f0","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.family","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":160,"y":560,"wires":[["99e33ba9ccc6fa6d"]]},{"id":"db90d9d61a7543c1","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Heating Mode Home","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Home\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":340,"wires":[[]]},{"id":"544875b2eee3f9fd","type":"switch","z":"f1fbd0e36d0809e6","name":"Set Heating Mode","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"home","vt":"str"},{"t":"eq","v":"not_home","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":380,"wires":[["db90d9d61a7543c1"],["bcec92d917d795c2"]]},{"id":"bcec92d917d795c2","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Heating Mode Away","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Away\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":420,"wires":[[]]},{"id":"99e33ba9ccc6fa6d","type":"api-current-state","z":"f1fbd0e36d0809e6","name":"Heating in Holiday Mode?","server":"aadbde09.d5ab3","version":2,"outputs":2,"halt_if":"Holiday","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.heating","state_type":"str","blockInputOverrides":false,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":560,"wires":[[],["544875b2eee3f9fd"]]},{"id":"0f46223f038b8ffe","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to 15","rules":[{"t":"set","p":"payload","pt":"msg","to":"15","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":880,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f","d6e05d4c270fa284","c3f778f6bc7085f3","f3dde576849f5a31"]]},{"id":"b30c5420f77c9cd8","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"Heating Mode Changed","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":400,"y":780,"wires":[["2850f34bfe231fb3"]]},{"id":"3a007527920cac82","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Main Heating","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.zentralheizung","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2410,"y":840,"wires":[[]]},{"id":"16d2d7751f2c61df","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to auto","rules":[{"t":"set","p":"payload","pt":"msg","to":"auto","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":660,"wires":[["92c6a75428833a41","56b8b37c133a2748","9f02e0b69803c80b","adb4d1901d14482f","9b3e89d8d89890dd"]]},{"id":"568ec230ad0e5745","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"Heating Mode Changed","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"Home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":680,"y":660,"wires":[["16d2d7751f2c61df"],[]]},{"id":"5c08655e39db6440","type":"debug","z":"f1fbd0e36d0809e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2300,"y":420,"wires":[]},{"id":"9b3e89d8d89890dd","type":"debug","z":"f1fbd0e36d0809e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1250,"y":600,"wires":[]},{"id":"aadbde09.d5ab3","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"f50788c8abb772f2","type":"light-scheduler-settings","name":"Home","latitude":"48.100645","longitude":"16.305638"}]
Unfortunately the “home” part does not set any temperatures anymore.
To use it as a conditional you have to send trigger and it will evaluate the schedule and output accordingly. Then return to auto mode.
[{"id":"92c6a75428833a41","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}}]","topic":"","name":"Day / Night Kids","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1340,"y":80,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f"]]},{"id":"56b8b37c133a2748","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Day / Night Sleeping Room","onPayload":"on","onPayloadType":"str","offPayload":"off","offPayloadType":"str","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1380,"y":200,"wires":[["04ee1386bc0ab20b"]]},{"id":"9f02e0b69803c80b","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":540}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":540}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":540}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":540}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":540}},{\"start\":{\"dow\":6,\"mod\":420},\"end\":{\"dow\":6,\"mod\":600}},{\"start\":{\"dow\":0,\"mod\":420},\"end\":{\"dow\":0,\"mod\":600}}]","topic":"","name":"Day / Night Bath Room","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1360,"y":360,"wires":[["c3f778f6bc7085f3"]]},{"id":"adb4d1901d14482f","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1380}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1380}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1380}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1380}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1380}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1380}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1380}}]","topic":"","name":"Day / Night Living Room","onPayload":"23","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1370,"y":460,"wires":[["f3dde576849f5a31"]]},{"id":"16d2d7751f2c61df","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to trigger a time check","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":540,"wires":[["92c6a75428833a41","56b8b37c133a2748","9f02e0b69803c80b","adb4d1901d14482f","9b3e89d8d89890dd","86122da60d82134a"]]},{"id":"568ec230ad0e5745","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"Heating Mode Changed","server":"6b1110b5.183a4","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"Home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":560,"y":660,"wires":[["16d2d7751f2c61df"],[]]},{"id":"9b3e89d8d89890dd","type":"debug","z":"f1fbd0e36d0809e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1370,"y":540,"wires":[]},{"id":"7ecabdde0b2ef462","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to auto","rules":[{"t":"set","p":"payload","pt":"msg","to":"auto","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":660,"wires":[["adb4d1901d14482f","9f02e0b69803c80b","56b8b37c133a2748","92c6a75428833a41"]]},{"id":"86122da60d82134a","type":"delay","z":"f1fbd0e36d0809e6","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":940,"y":600,"wires":[["7ecabdde0b2ef462"]]},{"id":"f50788c8abb772f2","type":"light-scheduler-settings","name":"Home","latitude":"","longitude":""},{"id":"6b1110b5.183a4","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Thanks for your help, it is working now!
Hi!
Unfortunately this stopped working for me.
My automation now only works when the presence-state (home, away or holiday) changes.
The light scheduler does not trigger a new value when it switches between on and off.
Example: Light Scheduler “Day / Night Living Room” should change the set temperature at 06:00 and 23:00 but it does not do anything.
Here is my current flow:
[{"id":"f1fbd0e36d0809e6","type":"tab","label":"Heating 2","disabled":false,"info":""},{"id":"a8d97d4fe395a4aa","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Hannahs Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_hannahs_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2420,"y":1160,"wires":[[]]},{"id":"92c6a75428833a41","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}}]","topic":"","name":"Day / Night Kids Holiday","onPayload":"22.5","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1850,"y":880,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f"]]},{"id":"7791bcc7a4b7ad8f","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Lenas Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_lenas_zimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2410,"y":1220,"wires":[[]]},{"id":"56b8b37c133a2748","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Day / Night Sleeping Room","onPayload":"on","onPayloadType":"str","offPayload":"off","offPayloadType":"str","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1800,"y":1000,"wires":[["04ee1386bc0ab20b"]]},{"id":"9f02e0b69803c80b","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":540}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":540}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":540}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":540}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":540}},{\"start\":{\"dow\":6,\"mod\":420},\"end\":{\"dow\":6,\"mod\":600}},{\"start\":{\"dow\":0,\"mod\":420},\"end\":{\"dow\":0,\"mod\":600}}]","topic":"","name":"Day / Night Bath Room","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1780,"y":1160,"wires":[["c3f778f6bc7085f3"]]},{"id":"c3f778f6bc7085f3","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Bath","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_badezimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2660,"y":1520,"wires":[[]]},{"id":"adb4d1901d14482f","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1380}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1380}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1380}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1380}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1380}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1380}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1380}}]","topic":"","name":"Day / Night Living Room","onPayload":"23.5","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1790,"y":1260,"wires":[["f3dde576849f5a31"]]},{"id":"f3dde576849f5a31","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Living Room & Kitchen","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.temperatur_wohnzimmer","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2520,"y":1660,"wires":[[]]},{"id":"04ee1386bc0ab20b","type":"switch","z":"f1fbd0e36d0809e6","name":"Heat Yes/No","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":2040,"y":980,"wires":[["f0516c82e8c50411"],["9cac579858ef364f"]]},{"id":"d6e05d4c270fa284","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Sleeping Room","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_schlafzimmer_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2900,"y":1360,"wires":[[]]},{"id":"31ac6e26b4de07d2","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":1285},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":1285},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":1285},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":1285},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":1285},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":1285},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":1285},\"end\":{\"dow\":1,\"mod\":0}}]","topic":"","name":"Normal or Evening Boost","onPayload":"23","onPayloadType":"num","offPayload":"20","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":2610,"y":920,"wires":[["d6e05d4c270fa284"]]},{"id":"2850f34bfe231fb3","type":"switch","z":"f1fbd0e36d0809e6","name":"Set Heating Path","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Away","vt":"str"},{"t":"eq","v":"Vacation","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1090,"y":1580,"wires":[["ca332450895580ef"],["0f46223f038b8ffe"]]},{"id":"9cac579858ef364f","type":"change","z":"f1fbd0e36d0809e6","name":"Set to Night Temperature","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":2250,"y":1020,"wires":[["d6e05d4c270fa284"]]},{"id":"ca332450895580ef","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to 18","rules":[{"t":"set","p":"payload","pt":"msg","to":"18","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1400,"y":1580,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f","d6e05d4c270fa284","c3f778f6bc7085f3","f3dde576849f5a31"]]},{"id":"9121355fb43bb4f0","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.family","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":580,"y":1360,"wires":[["99e33ba9ccc6fa6d"]]},{"id":"db90d9d61a7543c1","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Heating Mode Home","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Home\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1310,"y":1140,"wires":[[]]},{"id":"544875b2eee3f9fd","type":"switch","z":"f1fbd0e36d0809e6","name":"Set Heating Mode","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"home","vt":"str"},{"t":"eq","v":"not_home","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":1180,"wires":[["db90d9d61a7543c1"],["bcec92d917d795c2"]]},{"id":"bcec92d917d795c2","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Heating Mode Away","server":"aadbde09.d5ab3","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.heating","data":"{\"option\":\"Away\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1310,"y":1220,"wires":[[]]},{"id":"99e33ba9ccc6fa6d","type":"api-current-state","z":"f1fbd0e36d0809e6","name":"Heating in Holiday Mode?","server":"aadbde09.d5ab3","version":3,"outputs":2,"halt_if":"Holiday","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.heating","state_type":"str","blockInputOverrides":false,"outputProperties":[],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":1360,"wires":[[],["544875b2eee3f9fd"]]},{"id":"0f46223f038b8ffe","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to 15","rules":[{"t":"set","p":"payload","pt":"msg","to":"15","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1400,"y":1680,"wires":[["a8d97d4fe395a4aa","7791bcc7a4b7ad8f","d6e05d4c270fa284","c3f778f6bc7085f3","f3dde576849f5a31"]]},{"id":"b30c5420f77c9cd8","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"Heating Mode Changed","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":820,"y":1580,"wires":[["2850f34bfe231fb3"]]},{"id":"16d2d7751f2c61df","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to auto","rules":[{"t":"set","p":"payload","pt":"msg","to":"auto","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1390,"y":1520,"wires":[["56b8b37c133a2748","9f02e0b69803c80b","adb4d1901d14482f","9b3e89d8d89890dd","9997e5767b79fa45","e57f928bd4b8c250","92c6a75428833a41","bc4ef471bc2122e1","21ca811a053092fe"]]},{"id":"568ec230ad0e5745","type":"server-state-changed","z":"f1fbd0e36d0809e6","name":"Heating Mode Changed","server":"aadbde09.d5ab3","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.heating","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"Home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":1080,"y":1480,"wires":[["77510ca421a00533"],[]]},{"id":"9b3e89d8d89890dd","type":"debug","z":"f1fbd0e36d0809e6","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1690,"y":1400,"wires":[]},{"id":"77510ca421a00533","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to trigger a time check","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300,"y":1360,"wires":[["8acc180526657d08","56b8b37c133a2748","9f02e0b69803c80b","adb4d1901d14482f","9997e5767b79fa45","e57f928bd4b8c250","1206145382cc2e3c","20fd6e21ee073622"]]},{"id":"8acc180526657d08","type":"delay","z":"f1fbd0e36d0809e6","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1390,"y":1440,"wires":[["16d2d7751f2c61df"]]},{"id":"f0516c82e8c50411","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to trigger a time check","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2220,"y":840,"wires":[["9e3fced6ffa37730","31ac6e26b4de07d2"]]},{"id":"9e3fced6ffa37730","type":"delay","z":"f1fbd0e36d0809e6","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":2280,"y":900,"wires":[["5d16fa5635fd2161"]]},{"id":"5d16fa5635fd2161","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to auto","rules":[{"t":"set","p":"payload","pt":"msg","to":"auto","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2290,"y":960,"wires":[["31ac6e26b4de07d2"]]},{"id":"9997e5767b79fa45","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":360},\"end\":{\"dow\":1,\"mod\":1200}},{\"start\":{\"dow\":4,\"mod\":360},\"end\":{\"dow\":4,\"mod\":1200}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1200}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1200}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1200}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1200}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1200}}]","topic":"","name":"Day / Night Entrance","onPayload":"18","onPayloadType":"num","offPayload":"16","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1780,"y":1080,"wires":[["348be1199d9ff7a8"]]},{"id":"348be1199d9ff7a8","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | Entrance","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_windfang_heating_1","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2060,"y":1100,"wires":[[]]},{"id":"25c6c7dc8836a1f0","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | LF Foyer","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_ug_vorzimmer_heating_1, climate.vorzimmer_ug","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2400,"y":1320,"wires":[[]]},{"id":"caccd1216dbcf166","type":"api-call-service","z":"f1fbd0e36d0809e6","name":"Set Temperature | UF Foyer","server":"aadbde09.d5ab3","version":3,"debugenabled":true,"service_domain":"climate","service":"set_temperature","entityId":"climate.heizkorper_og_vorzimmer_heating_1, climate.vorzimmer_og","data":"{\"temperature\": {{payload}}}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2400,"y":1360,"wires":[[]]},{"id":"e57f928bd4b8c250","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":300},\"end\":{\"dow\":1,\"mod\":1200}},{\"start\":{\"dow\":4,\"mod\":305},\"end\":{\"dow\":4,\"mod\":1200}},{\"start\":{\"dow\":2,\"mod\":360},\"end\":{\"dow\":2,\"mod\":1200}},{\"start\":{\"dow\":3,\"mod\":360},\"end\":{\"dow\":3,\"mod\":1200}},{\"start\":{\"dow\":5,\"mod\":360},\"end\":{\"dow\":5,\"mod\":1200}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1200}},{\"start\":{\"dow\":0,\"mod\":355},\"end\":{\"dow\":0,\"mod\":1200}}]","topic":"","name":"Day / Night Foyer","onPayload":"21","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1770,"y":1340,"wires":[["25c6c7dc8836a1f0","caccd1216dbcf166"]]},{"id":"cf42428acae9b5b1","type":"function","z":"f1fbd0e36d0809e6","name":"set main heating -1","func":"msg.payload = msg.payload - 2\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2770,"y":1760,"wires":[[]]},{"id":"1206145382cc2e3c","type":"feiertageAT","z":"f1fbd0e36d0809e6","name":"Feiertage AT","local":"DE","neujahr":true,"neujahrName":"Neujahr","heiligeDreiKoenige":true,"heiligeDreiKoenigeName":"Heilige drei Könige","stJosef":true,"stJosefName":"St. Josef","gruendonnerstag":true,"gruendonnerstagName":"Gründonnerstag","karfreitag":true,"karfreitagName":"Karfreitag","easterSunday":true,"easterSundayName":"Ostersonntag","easterMonday":true,"easterMondayName":"Ostermontag","firstMay":true,"firstMayName":"Staatsfeiertag","stFlorian":true,"stFlorianName":"St. Florian","christiHimmelfahrt":true,"christiHimmelfahrtName":"Christi Himmelfahrt","pfingstsonntag":true,"pfingstsonntagName":"Pfingstsonntag","pfingstmontag":true,"pfingstmontagName":"Pfingstmontag","fronleichnam":true,"fronleichnamName":"Fronleichnam","mariaHimmelfahrt":true,"mariaHimmelfahrtName":"Maria Himmelfahrt","stRupert":true,"stRupertName":"St. Rupert","tagDerVolksabstimmung":true,"tagDerVolksabstimmungName":"Tag der Volksabstimmung","nationalfeiertagAT":true,"nationalfeiertagATName":"Nationalfeiertag","halloween":true,"halloweenName":"Halloween","allerheiligen":true,"allerheiligenName":"Allerheiligen","stMartin":true,"stMartinName":"St. Martin","stLeopold":true,"stLeopoldName":"St. Leopold","nikolaus":true,"nikolausName":"Nikolaus","mariaeEmpfaengnis":true,"mariaeEmpfaengnisName":"Mariä Empfängnis","advent1":true,"advent1Name":"1. Advent","advent2":true,"advent2Name":"2. Advent","advent3":true,"advent3Name":"3. Advent","advent4":true,"advent4Name":"4. Advent","heiligabend":true,"heiligabendName":"Heiligabend","weihnachten1":true,"weihnachten1Name":"Weihnachten","weihnachten2":true,"weihnachten2Name":"Stefanitag","silvester":true,"silvesterName":"Silvester","ownHoliday1":false,"ownHoliday1Day":1,"ownHoliday1Month":1,"ownHoliday1Name":"own Date 1","ownHoliday2":false,"ownHoliday2Day":2,"ownHoliday2Month":2,"ownHoliday2Name":"own Date 2","ownHoliday3":false,"ownHoliday3Day":3,"ownHoliday3Month":3,"ownHoliday3Name":"own Date 3","ownHoliday4":false,"ownHoliday4Day":4,"ownHoliday4Month":4,"ownHoliday4Name":"own Date 4","ownHoliday5":false,"ownHoliday5Day":5,"ownHoliday5Month":5,"ownHoliday5Name":"own Date 5","ownHoliday6":false,"ownHoliday6Day":6,"ownHoliday6Month":6,"ownHoliday6Name":"own Date 6","ownHoliday7":false,"ownHoliday7Day":7,"ownHoliday7Month":7,"ownHoliday7Name":"own Date 7","ownHoliday8":false,"ownHoliday8Day":8,"ownHoliday8Month":8,"ownHoliday8Name":"own Date 8","ownHoliday9":false,"ownHoliday9Day":9,"ownHoliday9Month":9,"ownHoliday9Name":"own Date 9","ownHoliday10":false,"ownHoliday10Day":10,"ownHoliday10Month":10,"ownHoliday10Name":"own Date 10","array":false,"x":1230,"y":780,"wires":[["412d2ad2259e7332"]]},{"id":"412d2ad2259e7332","type":"switch","z":"f1fbd0e36d0809e6","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"false","repair":false,"outputs":2,"x":1390,"y":780,"wires":[["30abfebeac44b396"],["93ed1843da795f90"]]},{"id":"bc4ef471bc2122e1","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":1,\"mod\":930},\"end\":{\"dow\":1,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":930},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":930},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":930},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":5,\"mod\":750},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}}]","topic":"","name":"Day / Night Hannah Workday","onPayload":"22.5","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1860,"y":740,"wires":[["a8d97d4fe395a4aa"]]},{"id":"21ca811a053092fe","type":"light-scheduler","z":"f1fbd0e36d0809e6","settings":"f50788c8abb772f2","events":"[{\"start\":{\"dow\":5,\"mod\":750},\"end\":{\"dow\":5,\"mod\":1260}},{\"start\":{\"dow\":6,\"mod\":360},\"end\":{\"dow\":6,\"mod\":1260}},{\"start\":{\"dow\":0,\"mod\":360},\"end\":{\"dow\":0,\"mod\":1260}},{\"start\":{\"dow\":4,\"mod\":750},\"end\":{\"dow\":4,\"mod\":1260}},{\"start\":{\"dow\":3,\"mod\":750},\"end\":{\"dow\":3,\"mod\":1260}},{\"start\":{\"dow\":2,\"mod\":750},\"end\":{\"dow\":2,\"mod\":1260}},{\"start\":{\"dow\":1,\"mod\":750},\"end\":{\"dow\":1,\"mod\":1260}}]","topic":"","name":"Day / Night Lena Workday","onPayload":"22.5","onPayloadType":"num","offPayload":"18","offPayloadType":"num","onlyWhenDark":false,"scheduleRndMax":0,"sunElevationThreshold":6,"sunShowElevationInStatus":false,"outputfreq":"output.statechange","x":1850,"y":780,"wires":[["7791bcc7a4b7ad8f"]]},{"id":"20fd6e21ee073622","type":"debug","z":"f1fbd0e36d0809e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1540,"y":920,"wires":[]},{"id":"30abfebeac44b396","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to trigger a time check","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1520,"y":840,"wires":[["92c6a75428833a41"]]},{"id":"93ed1843da795f90","type":"change","z":"f1fbd0e36d0809e6","name":"Set msg.payload to trigger a time check","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1520,"y":720,"wires":[["bc4ef471bc2122e1","21ca811a053092fe","ce12ec3bef030e47"]]},{"id":"ce12ec3bef030e47","type":"debug","z":"f1fbd0e36d0809e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1760,"y":640,"wires":[]},{"id":"7b8b6c4f9c661faa","type":"inject","z":"f1fbd0e36d0809e6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":850,"y":1500,"wires":[["77510ca421a00533"]]},{"id":"aadbde09.d5ab3","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"},{"id":"f50788c8abb772f2","type":"light-scheduler-settings","name":"Home","latitude":"48.100645","longitude":"16.305638"}]
Any idea why this is not working anymore? May there be an issue with Light Scheduler?
Thanks!
I don’t use it but taking a quick look it seems auto takes light levels into consideration. Try sending schedule-only instead of auto.
