Node red: how to read a file from within a function
hi,
I know there is a readFile node, but I’d like to read a file as part of a function node.
I seem to be unable to find any info on that.
does anyone have an example to get me started?
thanks,
wolfgang
My first reaction is - just don’t. The whole point of Node Red is to combine small well-tested components that each do only one operation.
Also, the code within the function node is single-threaded and will block execution.
Why is it that you don’t want to use the “read file” node?
Thanks for your answer.
I am working on an algorithm that decides how to charge a home battery depending on multiple parameters and thought it might be cleaner (for me) to keep all the work inside this one function, but yes, I can do the reading and writing via nodes.
