Now that http-request node will be gone when I update the node red add on, what should I be using to replace http-request?
Thanks.
Thanks.
I have the same question. I’m holding off updating until I know. Seems nuts to remove this as I’m using it in hundreds of my subflows.
I’m hoping the answer is “we have a migration and you don’t have to worry about it”
The one that was removed I think was the ‘www request’ node. The standard http in/request/response nodes are still available.
Thanks. It’s confusing when different nodes have the same name…
