So you’re not wanting to start a hue scene?
I don’t think I’m quite understanding the question, but here’s a motion flow I have using Hue lights, maybe it will help give you an idea.
[{"id":"2759a671.a17caa","type":"subflow","name":"Nightlight Lights off?","info":"","category":"","in":[{"x":40,"y":80,"wires":[{"id":"97ae16db.976fe8"}]}],"out":[{"x":640,"y":80,"wires":[{"id":"b39b1a4b.c6a6c8","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"97ae16db.976fe8","type":"api-current-state","z":"2759a671.a17caa","name":"TV lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.tv_strip","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":190,"y":80,"wires":[["697d0d91.347424"],[]]},{"id":"697d0d91.347424","type":"api-current-state","z":"2759a671.a17caa","name":"Pendant lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.pendants","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":290,"y":140,"wires":[["b39b1a4b.c6a6c8"],[]]},{"id":"b39b1a4b.c6a6c8","type":"api-current-state","z":"2759a671.a17caa","name":"Kitchen lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"group.kitchen_night_lights_automation","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":470,"y":80,"wires":[[],[]]},{"id":"988c6b12.5820a8","type":"tab","label":"test 4","disabled":false,"info":""},{"id":"54d030c5.0dcd8","type":"comment","z":"988c6b12.5820a8","name":"1. (Below) If it's dark out, and the Pendant and TV lights are off, turn on kitchen can 1 and 3 to 10% for 25 seconds on motion_____________","info":"","x":710,"y":260,"wires":[]},{"id":"fd2008c8.8ebcb8","type":"api-call-service","z":"988c6b12.5820a8","name":"Kitchen night lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"group.kitchen_night_lights","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1340,"y":320,"wires":[["786cf1aa.b7a7b"]]},{"id":"6c64ff8b.bcc18","type":"api-current-state","z":"988c6b12.5820a8","name":"Kitchen can 1 off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.kitchen_can_1","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1690,"y":380,"wires":[[],["fd2008c8.8ebcb8"]]},{"id":"5b0ba395.432d2c","type":"api-current-state","z":"988c6b12.5820a8","name":"Kitchen can 3 off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.kitchen_can_3","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1670,"y":260,"wires":[[],["fd2008c8.8ebcb8"]]},{"id":"9cea9357.6ebf4","type":"stoptimer","z":"988c6b12.5820a8","duration":"25","units":"Second","payloadtype":"num","payloadval":"0","name":"25sec","x":1130,"y":300,"wires":[["fd2008c8.8ebcb8"],[]]},{"id":"bb968cf9.34294","type":"time-range-switch","z":"988c6b12.5820a8","name":"","lat":"27.918805","lon":"-81.866830","startTime":"sunset","endTime":"sunrise","startOffset":0,"endOffset":0,"x":500,"y":300,"wires":[["8fa5a19f.b7e26"],[]]},{"id":"951e1965.2f0c98","type":"api-call-service","z":"988c6b12.5820a8","name":"Kitchen night lights on (10%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"group.kitchen_night_lights","data":"{\"brightness_pct\":10,\"transition\":6}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":940,"y":300,"wires":[["9cea9357.6ebf4"]]},{"id":"386ab42e.8c02ec","type":"server-state-changed","z":"988c6b12.5820a8","name":"Kitchen Motion","server":"26956a45.92d866","version":1,"entityidfilter":"sensor.kitchen_motion_burglar","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"8","halt_if_type":"num","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":320,"y":300,"wires":[["bb968cf9.34294"],[]]},{"id":"786cf1aa.b7a7b","type":"delay","z":"988c6b12.5820a8","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"10","nbRateUnits":"11","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1510,"y":320,"wires":[["5b0ba395.432d2c","6c64ff8b.bcc18"]]},{"id":"8fa5a19f.b7e26","type":"subflow:2759a671.a17caa","z":"988c6b12.5820a8","name":"Nightlight Lights off?","env":[],"x":700,"y":300,"wires":[["951e1965.2f0c98"]]},{"id":"26956a45.92d866","type":"server","z":"","name":"Hass.io","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
