Are you sure it fluctuates only from 10 to 9? Depending on how you build your flow it’ll notify you every time the value is below 10. That is, from 9 to 8, from 8 to 7, and so on. If you want it to notify only when it goes from above or equal10 to below 10 you should filter that.
[{"id":"762b3139.8cbbe","type":"switch","z":"ebd7f2e4.a2afc","name":"old state >= 10?","property":"data.old_state.state","propertyType":"msg","rules":[{"t":"gte","v":"10","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":470,"y":900,"wires":[["c3883c94.1a04b"]]},{"id":"c3883c94.1a04b","type":"switch","z":"ebd7f2e4.a2afc","name":"new state < 10?","property":"data.new_state.state","propertyType":"msg","rules":[{"t":"lt","v":"10","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":660,"y":900,"wires":[["97efca33.232868"]]},{"id":"772a9c84.3aad74","type":"server-state-changed","z":"ebd7f2e4.a2afc","name":"Batteries","server":"9405c3fe.d0a6c","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"your_batts","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"data","propertyType":"msg","value":"","valueType":"eventData"}],"x":300,"y":900,"wires":[["762b3139.8cbbe"]]},{"id":"97efca33.232868","type":"api-call-service","z":"ebd7f2e4.a2afc","name":"Notify","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":820,"y":900,"wires":[[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
