Today I have spent my day installing Hass.io on an Intel NUC with the help of Docker. Everything went fine (only a big struggle with my Z-wave stick), and my first nodes are running again. I was a former Domoticz user but decided to move to Home Assistant.
Because I am not really into coding I decided to install Node-Red inside Hass.io. I have got it running in a docker (no errors there) and I can start it inside Hass.io
The problem is that I got this message when I tried to build something in the editor. Cannot find what I have done wrong.
Yes I did, the button is ‘grey’ now. I can choose ‘restart flow’ which gives a successful answer.
I put an event on the board and below it it says ‘conected’. When I click on it I get the same message again…
This is, in node-red, where to configure the link between NR and HA. If you don’t use the add-on, you will have to unselect the “I use the Home…” and configure manually the access token and base url.
In a nutshell, if you use hassio, go for the addon !
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 6.1.4
You are running the latest version of this add-on.
System: Ubuntu 18.04.4 LTS (amd64 / intel-nuc)
Home Assistant Core: 0.107.7
Home Assistant Supervisor: 209
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
