I have installed Home Assistant (not Hassio) on a MacOS. I have also installed Node-Red on the same server. I am not able to find any information on how to integrate/configure Home Assistant and Node-Red. I am guessing something need to be added to the Configuration.Yaml? and something more? Please advice. Any suggestions and ideas are welcome.
Rgds
Jan
You don’t need to add anything to your Home Assistant configuration for Node-RED to work. NR will connect to your Home Assistant instance. First you need to search for the node-red-contrib-home-assistant-websocket
palette inside NR and install it. Once you’ve done that, any HA node you add to a flow will require you to provide the details of your Home Assistant server so NR can connect to it.
