Node-RED partially works with ISY. “Fast-on” command works. But I can’t get light dimmer switches to dim.
I can get the below examples to work fine with a card in lovelace.
Node-RED requires I put all commands into a JSON format (which adds complexity vs. yaml) so you sometimes have to guess the format based on the node-RED prompt.
This works:
This doesn’t (though command is accepted with no errors):
I’ve followed the format node-red suggests (“value” format) and command is accepted but it fails.
Help??
