I want to inegrate Node-RED with my home assistant installation (via container homeassistant/raspberrypi3-homeassistant)
I easily set up Node-RED running the container nodered/node-red-docker:rpi-v8
Now I was wondering how Node-RED talks with Home Assistant.
My understand is that nodes talk with Home Assistant via api so I need to configure first in HA the http api password like:
http:
api_password !secret my_password_api
Then I need to configure this section in Node-RED:
Unfortunately when I did it I started to got a lot of authentication errors on the HA logs coming from the IP of my Raspberry (where I run both HA and Node-RED).
Which IP did you type in? Or other in which mode is your Node-Red container running? Does it have an own IP? I would suppose that you try http://localhost:8123 if HA and Node-Red are using the same IP and if Node-Red has it own IP you should try the IP of HA instead of “localhost”.
I am running both in a container on my QNAP NAS. Both have different IPs. For me it work well using the IP from HA in Node-Red
Does Node-Red work? It didn’t get any authentication error … So I assume that something is wrong with your setup.
I am using the “node-red-contrib-home-assistant-websocket” addon in Node-Red connecting to HA. But I had to update node.js and something else manually. See: node-red-contrib-home-assistant-websocket
Folks I am having the same issues, I have home assistant and eclipse-mosquitto running using host mode - same ip. I am not able to get the node-red working especially setting up the home assistant server. Please advise.
I solved the issue installing websocket version of HA palette nodes (node-red-contrib-home-assistant-websocket) and using a long term token as authentication method.
What version are you running on the docker and can you send me the installation steps. I cant seem to find instructions for node-red installation on qnap online. Where are the folders located for the node-red instance? Some screen shots without the credentials will be helpful. TIA.
In HA GUI clivk on your user profile in the top left, this will open a new page where you can generate tokens and at the bottom the option to generate a long term token.
Agree it’s a bit counter intuitive as it’s under user section and not under the configuration page (which is where I went looking for it initially)
Thank you that worked. pheew! Now on to the next hurdle. Have you guys installed the H/usbzb-1 stick on the QNAP HA. Any pointers/instructions will be helpful
