Node Red integration question
Sorry if this is a dumb question. Is the Node-Red companion integration through HACS required to run Node-Red? I have the Node-Red already installed through the supervisor add on store. I’m just trying to clean up some disc space and noticed this in my HACS integrations. Note: I do use Node-Red heavily and have many “virtual switches” created within Node-Red that are exposed to HA.
required - no but you get some REALLY cool capabilities when you do - like adding a node that creates a sensor in your flow that shows back in HA without having to create yet another template…
Yes it is required to create entities inside home assistant.
