Node Red: invalid configuration - data
Hello
I hope someone can help me
I wanted to change something in the flow today. I noticed that every time I use a home assistant node, there are warnings (red triangle). I can apply the changes and it works fine. However, it is very annoying. Nothing appears in the log (debug). I don’t know when it occurred first time. I’m attaching a screenshot.
At the time i created the flow it worked without any errors
Node Red 17.0.3
Thanks in advance
After the deploy and reload the page the triangle is gone
What do you have in the ‘Data’ field for those Call Service nodes?
Simply nothing…
I figured it out
I missed to keep the “node-red-contrib-home-assistant-websocket” up to date
After an palette update all is fine again
TNX
Just want to call out that this is risky for add-on users. palettes are updated with the add-on.
Home assistant nodes DO NOT update with the addon. You have to do it manually by going to the palette manger and clicking update.
