Hello Guys,
iam very new to Home Assistant but it worked good so far.
Now i got an Problem where i try now since some Hours.
I installed Node Red, and everything seems to work fine, i created a Timestamp i got no Errors but my Lights dont Change, i see all my lights in the Enity Id Section so Home Assistant must be connected, Also i can send states from Home Assistant to Node Red
Did i missed Something or need to add in Home Assistant?
Is Home Assistan may Blocking Node Red?
I got 2 Pictures where you can see what i did.
1 i pressed the Time Stamp, then i Put my Wled Light in Home Assistant off and On.
Thx in Advance for any Help
Chriss
