Anybody knows if it is possible to have a events:state node or similar that only triggers if the state change comes outside from Node-RED?
For example i have a switch that is turned on/off inside a flow but can also be turned on/off directly in homeassistant. I would like to have another flow that only triggers when the switch is changed outside of Node-RED.
