Hi, I have been using node-red for long time and every thing was perfect. today it seems that node red is not starting anymore. I press the start bottom and noting happens.
the log is:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 6 packages in 1s
found 0 vulnerabilities
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[11:46:30] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
31 Mar 11:46:34 - [info]
Welcome to Node-RED
31 Mar 11:46:34 - [info] Node-RED version: v3.0.2
31 Mar 11:46:34 - [info] Node.js version: v18.14.2
31 Mar 11:46:34 - [info] Linux 5.15.84-v8 arm64 LE
31 Mar 11:46:36 - [info] Loading palette nodes
31 Mar 11:46:41 - [info] Dashboard version 3.4.0 started at /endpoint/ui
31 Mar 11:46:43 - [info] Settings file : /etc/node-red/config.js
31 Mar 11:46:43 - [info] Context store : 'default' [module=memory]
31 Mar 11:46:43 - [info] User directory : /config/node-red/
31 Mar 11:46:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Mar 11:46:43 - [info] Flows file : /config/node-red/flows.json
31 Mar 11:46:43 - [warn] Encrypted credentials not found
31 Mar 11:46:43 - [info] Server now running at http://127.0.0.1:46836/
31 Mar 11:46:43 - [info] Starting flows
31 Mar 11:46:43 - [info] Started flows
[11:46:43] INFO: Starting NGinx...
31 Mar 11:46:45 - [error] [api-call-service:Turn Terrace Light Strip Off] Call-Service attempted without connection to server.
31 Mar 11:46:45 - [error] [api-call-service:Turn Ava Color Light Off] Call-Service attempted without connection to server.
31 Mar 11:46:45 - [error] [api-call-service:Turn Ava Light Strip Off] Call-Service attempted without connection to server.
31 Mar 11:46:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
31 Mar 11:46:48 - [info] [server:Home Assistant] Connected to http://supervisor/core
So it seams that node-red is already started. but then I get error when I want to start it:
Node-RED
Add-on is not running. Please start it first
Please let me know if I need to provide more info.
Thanks in advanced for your help
