After playing with this till late last night and early this morning which included rebuilding the node, restarting Node red, restarting HA, the server and restoring the bulbs.
I feel that the node red flow does not override the bulb setting. If i increase the bulb’s setting on their web page node red does not reduce the brightness. Conversely If i reduce the bulbs setting node red will not increase the brightness
However using my native Home assistant automation used to perform the same function the light works brilliantly
Once again thank you for the time your taking and for your help
I had similar issue with IKEA bulb. Try {“brightness”:20}. Worked for me. Similar thing if you want to change your light temperature, some bulbs works with kelvins other ones with mired scale.
I ended up changing the bulb. Initially I was an dimmable RGBW led e27 from shelly. I replaced it with a dimmable e27 white bulb from shelly and it worked.
The issue was not a faulty bulb, just the bulb model.
I escalated this to the shelly support, however in my experience they are not too helpful and i don’t expect a response from them
