I can not figure out how to find what person turned the AC on or off. I need to know for validation for knowing if the AC was turned on by node-red (in this case the automation can continue) but if the AC was turned on by any other person exept “supervisor” I dont’t want my automation to execute any other automation.
Automation works like
When solar panels produce enough power, AC turnes on, when there is no Sun powering the panels It turns off. This is perfect, but I want to put a validation if the AC was turned on by me (any other person than “supervisor”) then AC should keep running and not turns off when other node tells (there is no Sun, turn off).
Can somebody help how to figure this out? Thank you
