Node Red LUX triggered lighting with motion detection and time
Good Day to you all,
TLDR; I moved to HA from Google Home after becoming disenchanted with the automation options available within the Google ecosystem. I’ve been attempting unsuccessfully to harness the power of my entities but keep finding my logic within Node Red shortcoming. I’ve spent a while trying to work it out myself however feel it’s time to see if any more learned folk can help.
- What are you trying to achieve using Node Red?
  • I have a group of lights in the lounge which I want to turn on when the LUX value falls to < 130 LUX.
  • I want the lights to come on when I am in the home and a binary motion sensor is activated between Golden hour -60 minutes and 06:00 the following day.
  • I want the lights to switch off when i enter the bedroom when either a binary motion sensor is triggered or a Google TV dongle is activated on my bedroom TV.
  • I am trying to avoid sending multiple on or off commands to the group of lights once any of the above scenarios have been satisfied. (IE once the motion sensor detects once it doesn’t need to trigger the same message over and over each time motion detected).
Here is the output of my most recent attempt, previous attempts have been cast aside and deleted:
        "id": "de4bad951531f479",
        "type": "tab",
        "label": "Lounge lighting",
        "disabled": true,
        "info": "",
        "env": []
        "id": "ab2afe209edc24c5",
        "type": "group",
        "z": "de4bad951531f479",
        "name": "Turn lights on",
        "style": {
            "stroke": "#92d04f",
            "fill": "#ffffff",
            "label": true,
            "color": "#000000"
        "nodes": [
            "df9c720eacb956c6",
            "031c68077bc18dac",
            "1617355ebacc4db2",
            "88930498b53f17e3",
            "789a1733450dc243",
            "ea91d5e05a174083",
            "96bfc1504188fcac"
        "x": 14,
        "y": 59,
        "w": 752,
        "h": 182
        "id": "de13bd6c88f923d0",
        "type": "group",
        "name": "Turn lights off ",
        "style": {
            "stroke": "#ff0000",
            "fill": "#ffffff",
            "label": true,
            "color": "#000000"
        "nodes": [
            "f9c374f9ad311072",
            "0cb74b0f0cc19e6b",
            "2124e5dbfff90f15",
            "32456236fa902737",
            "07d1d970d74a53c9"
        "x": 14,
        "y": 259,
        "w": 612,
        "h": 162
        "id": "3564d90281a0a6e7",
        "type": "group",
        "name": "Bedroom TV on?",
        "style": {
            "fill": "#ffffff",
            "label": true,
            "color": "#000000"
        "nodes": [
            "9875a68d5b7e2b35",
            "0f93a5417d18341f",
            "c2a808b1132d86ae"
        "x": 14,
        "y": 439,
        "w": 612,
        "h": 82
        "id": "df9c720eacb956c6",
        "type": "api-current-state",
        "g": "ab2afe209edc24c5",
        "name": "LUX level <130",
        "server": "c87d326ff07b7f8c",
        "version": 3,
        "outputs": 2,
        "halt_if": "130",
        "halt_if_type": "num",
        "halt_if_compare": "lt",
        "entity_id": "sensor.lux_sensor_illuminance",
        "state_type": "num",
        "blockInputOverrides": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 340,
        "y": 100,
        "wires": [
                "1617355ebacc4db2"
        "id": "031c68077bc18dac",
        "type": "inject",
        "name": "Interval",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "60",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 120,
        "y": 100,
        "wires": [
                "df9c720eacb956c6"
        "id": "1617355ebacc4db2",
        "type": "time-range-switch",
        "name": "",
        "lat": "oops",
        "lon": "oops",
        "startTime": "08:00",
        "endTime": "06:00",
        "startOffset": "-60",
        "endOffset": 0,
        "x": 540,
        "y": 100,
        "wires": [
                "ea91d5e05a174083"
        "id": "88930498b53f17e3",
        "type": "trigger-state",
        "name": "Lounge Sensor",
        "server": "b2dc7545.2e5d78",
        "version": 4,
        "inputs": 1,
        "outputs": 2,
        "exposeAsEntityConfig": "",
        "entityId": "binary_sensor.lounge_motion_sensor_motion",
        "entityIdType": "exact",
        "debugEnabled": false,
        "constraints": [
                "targetType": "this_entity",
                "targetValue": "",
                "propertyType": "current_state",
                "propertyValue": "new_state.state",
                "comparatorType": "is",
                "comparatorValueDatatype": "str",
                "comparatorValue": "on"
        "customOutputs": [],
        "outputInitially": false,
        "stateType": "str",
        "enableInput": true,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "x": 300,
        "y": 200,
        "wires": [
                "96bfc1504188fcac"
        "id": "789a1733450dc243",
        "type": "api-call-service",
        "name": "Switch lights on",
        "version": 5,
        "debugenabled": false,
        "domain": "light",
        "service": "turn_on",
        "areaId": [
            "living_room"
        "deviceId": [],
        "entityId": [
            "light.group_living_room_lights"
        "data": "",
        "dataType": "jsonata",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 660,
        "y": 200,
        "wires": [
        "id": "ea91d5e05a174083",
        "name": "Home?",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "zone.home",
        "state_type": "str",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 120,
        "y": 200,
        "wires": [
                "88930498b53f17e3"
        "id": "f9c374f9ad311072",
        "g": "de13bd6c88f923d0",
        "name": "Bedroom Sensor",
        "version": 4,
        "inputs": 1,
        "outputs": 2,
        "constraints": [
                "targetValue": "",
        "stateType": "str",
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "x": 120,
        "y": 380,
        "wires": [
                "07d1d970d74a53c9"
        "id": "0cb74b0f0cc19e6b",
        "name": "Switch lights off",
        "version": 5,
        "domain": "light",
        "service": "turn_off",
        "areaId": [
            "living_room"
        "deviceId": [],
        "entityId": [
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 520,
        "y": 380,
        "wires": [
        "id": "2124e5dbfff90f15",
        "name": "Home?",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 380,
        "y": 300,
        "wires": [
                "f9c374f9ad311072"
        "id": "32456236fa902737",
        "name": "",
        "lat": "oops",
        "lon": "-oops",
        "startTime": "21:00",
        "endTime": "06:00",
        "startOffset": "",
        "endOffset": 0,
        "x": 120,
        "y": 300,
        "wires": [
                "2124e5dbfff90f15"
        "id": "96bfc1504188fcac",
        "type": "rbe",
        "name": "Send once",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 490,
        "y": 200,
        "wires": [
                "789a1733450dc243"
        "id": "07d1d970d74a53c9",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 330,
        "y": 380,
        "wires": [
                "0cb74b0f0cc19e6b"
        "id": "9875a68d5b7e2b35",
        "g": "3564d90281a0a6e7",
        "name": "Is bedroom TV on?",
        "version": 4,
        "inputs": 0,
        "outputs": 2,
        "entityId": "media_player.bedroom_tv",
        "constraints": [
                "targetValue": "",
                "comparatorValue": "playing"
        "stateType": "str",
        "enableInput": false,
        "x": 130,
        "y": 480,
        "wires": [
                "0f93a5417d18341f"
        "id": "0f93a5417d18341f",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 330,
        "y": 480,
        "wires": [
                "c2a808b1132d86ae"
        "id": "c2a808b1132d86ae",
        "name": "",
        "version": 5,
        "domain": "switch",
        "areaId": [
            "living_room"
        "deviceId": [
            "8f8b21c54afc68aba4c7830cdc41772a"
        "entityId": [
            "switch.smart_switch_2009220813078290831148e1e9346b7e_outlet"
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 520,
        "y": 480,
        "wires": [
        "id": "c87d326ff07b7f8c",
        "type": "server",
        "name": "Home Assistant",
        "version": 5,
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": ": ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "default",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": false
        "id": "b2dc7545.2e5d78",
        "type": "server",
        "addon": true,
        "cacheJson": true
Currently, my lights do not behave as intended and do not respect the timer. Any help on this would be gratefully received.
Best Wishes,
Trigger nodes do not really have an input. The input is only there to enable/disable that particular trigger node, It does not make it fire. It seems you are using it like a current state node. The current state is what you would use to stop additional messages.
If you are turning on a light send it through a current state with the light to be turned on as the entity. State set to on The first message will pass if the light is off, subsequent messages will be sent to the other output.
Using an event state it will only fire once when the state passes the settings in the node. The condition would need to fail and then pass again for the node to fire again. A trigger state will fire every time the condition is true without needing to fail first.
The time range node has the default lat an long setting, this must be set to your locale for it to know what time zone your in. Default is by Southampton, England. It will not save these setting, every time you drag one to the workspace you will need to set the location. If you copy/paste one that is already deployed it will copy the location.
[{"id":"52ea47ba2c2a462a","type":"server-state-changed","z":"de4bad951531f479","name":"lux","server":"6b1110b5.183a4","version":5,"outputs":2,"exposeAsEntityConfig":"","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"130","ifStateType":"num","ifStateOperator":"lt","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":770,"y":380,"wires":[["19dbda790cbfa4bd"],[]]},{"id":"19dbda790cbfa4bd","type":"api-current-state","z":"de4bad951531f479","name":"is light on or off","server":"6b1110b5.183a4","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":960,"y":380,"wires":[[],["5ff4d612d997e644"]]},{"id":"5ff4d612d997e644","type":"api-call-service","z":"de4bad951531f479","name":"light turn on","server":"6b1110b5.183a4","version":5,"debugenabled":false,"domain":"","service":"","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1180,"y":380,"wires":[[]]},{"id":"6b1110b5.183a4","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"id","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Thanks for the update and your input Mikefila,
Appreciated.
I’ve had a play with your suggestions and have incorporated what I think you are explaining into my current flow. I’m going to start with the lights on, to simplify my understanding/debugging and take it from there:
        "type": "tab",
        "disabled": false,
        "info": "",
        "env": []
        "id": "33d364f2ffe64269",
        "type": "server-state-changed",
        "name": "lux",
        "server": "6b1110b5.183a4",
        "version": 5,
        "outputs": 2,
        "entityId": "sensor.lux_sensor_illuminance",
        "stateType": "str",
        "ifState": "130",
        "ifStateType": "num",
        "ifStateOperator": "lt",
        "outputOnlyOnStateChange": true,
        "for": "0",
        "forType": "num",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 110,
        "y": 80,
        "wires": [
                "2274786c974b0b6a"
        "id": "2274786c974b0b6a",
        "name": "Home?",
        "version": 3,
        "outputs": 2,
        "halt_if": "1",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 280,
        "y": 80,
        "wires": [
                "bc95337f3cc1199c"
        "id": "ee63c2d8b958e4d8",
        "name": "is light on or off",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "entity_id": "light.group_living_room_lights",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 340,
        "y": 180,
        "wires": [
                "c2e19a6b313c7d90"
        "id": "eabc4b4389ea03e0",
        "name": "Lights turn on",
        "version": 5,
        "domain": "light",
        "areaId": [
            "living_room"
        "deviceId": [],
        "entityId": [
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 800,
        "y": 180,
        "wires": [
        "id": "c2e19a6b313c7d90",
        "name": "",
        "lat": "not this time",
        "lon": "not this time",
        "startTime": "goldenHour",
        "endTime": "07:00",
        "endOffset": 0,
        "x": 550,
        "y": 180,
        "wires": [
                "eabc4b4389ea03e0"
        "id": "bc95337f3cc1199c",
        "name": "Lounge motion sensor",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "entity_id": "binary_sensor.lounge_motion_sensor_motion",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 500,
        "y": 80,
        "wires": [
                "ee63c2d8b958e4d8"
        "id": "6b1110b5.183a4",
        "type": "server",
        "version": 5,
        "addon": true,
        "cacheJson": false,
        "heartbeat": false,
        "entitySelector": "id",
        "statusSeparator": "at: ",
        "statusHourCycle": "h23",
        "enableGlobalContextStore": true
        "type": "server",
        "version": 5,
        "addon": true,
        "cacheJson": true,
        "heartbeat": false,
Will see how this fares this evening and update here to help others on a similar path.
Beyond this, again thanks for your help.
Kind Regards,
