I was searching for momentatry switch and found nothing I could use. I thought I’d post my work here. I created this flow.
When you turn it on, it will trigger an action and turn off.
It creates a Switch in Home Assistant
to make it unique,
- change the “name” values in the My Switch element
- change the Entity ID in the Trigger and Turn Off elements
- replace the yellow and pink elements with your desired service/action.
You can import this within Node Red.
[{"id":"f012c7fb.d76df8","type":"trigger-state","z":"f69946fd.2ac1b8","name":"My Switch Trigger","server":"cd4403b5.968d1","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"switch.my_switch","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"odgjh18ppkk","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on"},{"id":"sr5e2tlj04","targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off"}],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":530,"y":720,"wires":[["69ef9e4.27b156","387cc7d7.1c98a8"],[]]},{"id":"69ef9e4.27b156","type":"api-call-service","z":"f69946fd.2ac1b8","name":"Turn Off My Switch","server":"cd4403b5.968d1","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"switch.my_switch","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":790,"y":740,"wires":[[]]},{"id":"41975c3.22290a4","type":"mqtt out","z":"f69946fd.2ac1b8","name":"","topic":"OpenZWave/1/command/setvalue/","qos":"","retain":"","broker":"250eeee2.afada2","x":1080,"y":700,"wires":[]},{"id":"9e5e096b.d2ef28","type":"ha-entity","z":"f69946fd.2ac1b8","name":"My Switch","server":"cd4403b5.968d1","version":1,"debugenabled":false,"outputs":2,"entityType":"switch","config":[{"property":"name","value":"My Switch"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:account-arrow-left"},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":310,"y":720,"wires":[[],[]],"outputLabels":["allowed","blocked"],"icon":"node-red/arduino.png"},{"id":"387cc7d7.1c98a8","type":"change","z":"f69946fd.2ac1b8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"ValueIDKey\":281476526391348,\"Value\":29}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":700,"wires":[["41975c3.22290a4"]]},{"id":"cd4403b5.968d1","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"250eeee2.afada2","type":"mqtt-broker","z":"","name":"192.168.1.8","broker":"192.168.1.8","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
