Hey guys,
first post here, so please forgive me if the are ettiquette and formatting errors.
I have a motion sensor that switches on my ceiling lamp. After two minutes of no motion, it is switched off again.
I want the light to stay on, when I use a switch to turn it on. So the motion sensor automation should be ignored.
I tried to achieve this by including the timer in the motion sensor flow and was hoping it wouldn’t activate, when I use another automation to operate my wall switch.
However, when I use the wall switch, the light still turns off and I do not know how to code the condition for it to only time itself, when being activated by the motion sensor.
Can anyone help me out here?
Appreciated!
This is my Node Red code:
[{"id":"2f0f9659afab76de","type":"server-state-changed","z":"119d1199edbe0381","name":"Motion Sensor","server":"3e4d51f1.af843e","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hue_motion_sensor_1_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"motion","valueType":"str"},{"property":"object","propertyType":"msg","value":"","valueType":"triggerId"}],"x":200,"y":1100,"wires":[["dac9ce93158f043d"],[]]},{"id":"5904a5ddb293049f","type":"api-current-state","z":"119d1199edbe0381","name":"lux reading <15","server":"3e4d51f1.af843e","version":3,"outputs":2,"halt_if":"15","halt_if_type":"num","halt_if_compare":"lt","entity_id":"sensor.hue_motion_sensor_1_illuminance","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"dark","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":560,"y":1060,"wires":[["d2e80b95b0e98f99"],[]]},{"id":"d2e80b95b0e98f99","type":"api-current-state","z":"119d1199edbe0381","name":"SZ_D","server":"3e4d51f1.af843e","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.decke_schlafzimmer","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"off","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":690,"y":1120,"wires":[[],["96e3f9dd073e44e1"]]},{"id":"dac9ce93158f043d","type":"time-range-switch","z":"119d1199edbe0381","name":"Time restriction","lat":"","lon":"","startTime":"14:00","endTime":"23:00","startOffset":0,"endOffset":0,"x":380,"y":1100,"wires":[["5904a5ddb293049f"],[]]},{"id":"96e3f9dd073e44e1","type":"api-call-service","z":"119d1199edbe0381","name":"SZ_D on","server":"3e4d51f1.af843e","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":["3593fb9d97b08be78ce0b15fd83cfc84"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"reset","valueType":"str"}],"queue":"none","x":840,"y":1100,"wires":[["680de4c218fe4743"]]},{"id":"278f38bf5dd5666e","type":"api-call-service","z":"119d1199edbe0381","name":"SZ_D off","server":"3e4d51f1.af843e","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.decke_schlafzimmer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1320,"y":1080,"wires":[[]]},{"id":"409d17384b78180d","type":"controltimer","z":"119d1199edbe0381","name":"delay","timerType":"delay","timerDurationUnit":"second","timerDurationType":"num","timerDuration":120,"timerLoopTimeoutUnit":"second","timerLoopTimeoutType":"num","timerLoopTimeout":0,"loopTimeoutMessageType":"str","loopTimeoutMessage":"LOOP_TIMEOUT","timerMaxLoopIterationsType":"num","timerMaxLoopIterations":0,"loopMaxIterationsMessageType":"str","loopMaxIterationsMessage":"MAX_LOOP_ITERATIONS","isConsecutiveStartActionTimerResetAllowed":false,"isRunningTimerProgressVisible":true,"outputReceivedMessageOnTimerTrigger":true,"outputReceivedMessageOnTimerHalt":false,"startTimerOnReceivalOfUnknownMessage":true,"resetTimerOnReceivalOfUnknownMessage":true,"isDebugModeEnabled":false,"timerTriggeredMessageType":"str","timerTriggeredMessage":"TIMER_TRIGGERED","timerHaltedMessageType":"str","timerHaltedMessage":"TIMER_HALTED","isStartActionEnabled":true,"isStopActionEnabled":true,"isResetActionEnabled":true,"isPauseActionEnabled":true,"isContinueActionEnabled":true,"actionPropertyNameType":"str","actionPropertyName":"payload","startActionNameType":"str","startActionName":"START","stopActionNameType":"str","stopActionName":"STOP","resetActionNameType":"str","resetActionName":"RESET","pauseActionNameType":"str","pauseActionName":"PAUSE","continueActionNameType":"str","continueActionName":"CONTINUE","x":1150,"y":1080,"wires":[["278f38bf5dd5666e"],[]]},{"id":"680de4c218fe4743","type":"join","z":"119d1199edbe0381","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1010,"y":1080,"wires":[["409d17384b78180d"]]},{"id":"81f7b617f53943ca","type":"server-state-changed","z":"119d1199edbe0381","name":"Motion Sensor","server":"3e4d51f1.af843e","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hue_motion_sensor_1_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"motion","valueType":"str"},{"property":"object","propertyType":"msg","value":"","valueType":"triggerId"}],"x":840,"y":1040,"wires":[["680de4c218fe4743"],[]]},{"id":"3e4d51f1.af843e","type":"server","name":"Home Assistant","addon":true}]
