I’ve decided to try to learn about Node-Red.
I found some tutorials as well as these examples of putting it to good use:
I have the Node-Red add-on installed. I was able to install the Schedex Node.
What I don’t understand is how to link the nodes to each other (grey line with little square boxes on each side), and how to use the provided code to configure the nodes.
For example, the Schedex node identified as “Sunset (-40min)” has this code associated with it:
"id": "8ceb3f91.1eb3",
"type": "schedex",
"z": "c97206b0.e99878",
"name": "Sunset (-40min) - 11PM",
"passthroughunhandled": false,
"suspended": false,
"lat": "37.338167",
"lon": "-121.885388",
"ontime": "sunset",
"ontopic": "",
"onpayload": "{\"service\":\"turn_on\",\"brightness_pct\":\"10\"}",
"onoffset": "-40",
"onrandomoffset": 0,
"offtime": "23:00",
"offtopic": "",
"offpayload": "{\"service\":\"turn_off\"}",
"offoffset": 0,
"offrandomoffset": 0,
"mon": true,
"tue": true,
"wed": true,
"thu": true,
"fri": true,
"sat": true,
"sun": true,
"x": 187,
"y": 311,
"wires": [
["bd73ab02.91e688"]
I see various fields in the configuration/settings of the node. But, how, for example, would I know to use an offpayload of:
Is there a list I can select or is it manual coding?
I know these are very basic questions, and might not even make sense as questions.
Any help would sure be appreciated.
Thank you
