My old router died yesterday and was replaced today. I’ve gone through an set everything up but the last piece is getting node-red to work again. The only address to HA was 192.168.178.19, it’s now 192.168.1.19. I’ve got HA on a static IP and I’ve gone into my flow.json and changed all the IPs to their new ones but it still fails to start. Here is the log
Welcome to Node-RED
10 Nov 14:00:15 - [info] Node-RED version: v3.1.0
10 Nov 14:00:15 - [info] Node.js version: v18.18.2
10 Nov 14:00:15 - [info] Linux 6.1.59 x64 LE
10 Nov 14:00:15 - [info] Loading palette nodes
10 Nov 14:00:20 - [info] RedBot version: 1.2.4 (node-red-contrib-chatbot)
10 Nov 14:00:21 - [info] Red Bot Mission Control is not enabled.
10 Nov 14:00:21 - [info] Enable it running with the REDBOT_ENABLE_MISSION_CONTROL environment variable:
10 Nov 14:00:21 - [info] REDBOT_ENABLE_MISSION_CONTROL=true node-red -u /my-user-dir
10 Nov 14:00:28 - [info] Dashboard version 3.6.1 started at /endpoint/ui
10 Nov 14:00:29 - [info] Settings file : /etc/node-red/config.js
10 Nov 14:00:29 - [info] Context store : 'default' [module=memory]
10 Nov 14:00:29 - [info] User directory : /config/node-red/
10 Nov 14:00:29 - [info] Projects directory: /config/node-red/projects
10 Nov 14:00:29 - [info] Server now running at http://127.0.0.1:46836/
10 Nov 14:00:29 - [info] Active project : HA
10 Nov 14:00:29 - [info] Flows file : /config/node-red/projects/HA/flows.json
10 Nov 14:00:29 - [info] Starting flows
10 Nov 14:00:29 - [error] [server:2f1g8h7i.654321] Error: No credentials provided
10 Nov 14:00:29 - [error] [server:63517380.eb951c] Error: No credentials provided
Tesla API: No token found. Getting new token now...
Tesla API: doing api call to fetch new access token
[14:00:29] INFO: Starting NGinx...
10 Nov 14:00:30 - [info] Started flows
10 Nov 14:00:30 - [info] [server:Home Assistant] Connecting to http://supervisor/core
10 Nov 14:00:30 - [error] [api-call-service:on] Call-Service attempted without connection to server.
10 Nov 14:00:30 - [error] [api-call-service:quiet time off] Call-Service attempted without connection to server.
Tesla API: access token OK
10 Nov 14:00:34 - [info] [server:Home Assistant] Connecting to http://supervisor/core
10 Nov 14:00:34 - [error] [api-current-state:Season] InputError: Entity could not be found in cache for entityId: sensor.season
10 Nov 14:00:34 - [error] [api-current-state:Nest] InputError: Entity could not be found in cache for entityId: climate.hallway_2
10 Nov 14:00:35 - [info] [server:Home Assistant] Connecting to http://supervisor/core
10 Nov 14:00:39 - [info] [server:Home Assistant] Connecting to http://supervisor/core
10 Nov 14:00:39 - [error] [api-current-state:Jeremy] InputError: Entity could not be found in cache for entityId: binary_sensor.jeremy_presence
10 Nov 14:00:39 - [error] [api-current-state:Deanna] InputError: Entity could not be found in cache for entityId: binary_sensor.deanna_presence
10 Nov 14:00:40 - [info] [server:Home Assistant] Connecting to http://supervisor/core
10 Nov 14:00:44 - [info] [server:Home Assistant] Connecting to http://supervisor/core
10 Nov 14:00:44 - [red] Uncaught Exception:
10 Nov 14:00:44 - [error] Error: Huejay: timeout of 15000ms exceeded
at /config/node-red/node_modules/huejay/lib/Transport.js:106:15
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at runNextTicks (node:internal/process/task_queues:64:3)
at listOnTimeout (node:internal/timers:538:9)
at processTimers (node:internal/timers:512:7)
[14:00:44] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[14:00:44] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
