I have been running Mosquitto MQTT on Home Assistant for over a year.
I am configuring NodeRed with a credential secret
For http_node and http_static I have entered the user name and password used with Mosquitto MQTT
I have turned off ssl
everything else has been left to its default.
When I click on ‘Start’ NodeRed does not start.
There are multiple entries in the log that say
13 Sep 17:40:16 - [info] [mqtt-broker:MQTT] Connection failed to broker: mqtt://localhost:1883
These settings are not MQTT related. Try removing them and restart. Is this a bare install? NR doesn’t require MQTT to operate unless you want to use those specific nodes.
Hmmm, I added an NR Flow that makes use of MQTT and the flow, including the MQTTT publish, worked. I tooked a look at the log, and after I ran my first publish the message about the MQTT Connection failing stopped appearing. I rebooted HA and it is all still working just fine.
Looks like all I needed to do was multiple reboots to get it going?
