I am having an issue with node red all the sudden after months of no issues at all in my HA instance. It will not start or let me get to the web ui every time I click start it never starts to run. I have restored backup and still no luck. I have deleted everything in node red folders and uninstalled and tried to start with fresh install and get same results. Weird thing is it is running cause my flows are working. I just can not access them. Any help would be greatly appreciated.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 23 packages in 1s
2 packages are looking for funding
run npm fund
for details
found 0 vulnerabilities
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[09:39:48] INFO: Starting Node-RED…
start
node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
3 Apr 09:39:52 - [info]
Welcome to Node-RED
3 Apr 09:39:52 - [info] Node-RED version: v3.0.2
3 Apr 09:39:52 - [info] Node.js version: v18.14.2
3 Apr 09:39:52 - [info] Linux 5.15.84-v8 arm64 LE
3 Apr 09:39:55 - [info] Loading palette nodes
3 Apr 09:40:01 - [info] Dashboard version 3.4.0 started at /endpoint/ui
3 Apr 09:40:02 - [info] Settings file : /etc/node-red/config.js
3 Apr 09:40:02 - [info] Context store : ‘default’ [module=memory]
3 Apr 09:40:02 - [info] User directory : /config/node-red/
3 Apr 09:40:02 - [warn] Projects disabled : editorTheme.projects.enabled=false
3 Apr 09:40:02 - [info] Flows file : /config/node-red/flows.json
3 Apr 09:40:02 - [warn] Encrypted credentials not found
3 Apr 09:40:02 - [info] Server now running at http://127.0.0.1:46836/
3 Apr 09:40:02 - [info] Starting flows
[09:40:03] INFO: Starting NGinx…
3 Apr 09:40:03 - [info] Started flows
3 Apr 09:40:04 - [error] [api-call-service:Morning Lights Off] Call-Service attempted without connection to server.
3 Apr 09:40:04 - [error] [api-call-service:Turn Off Brayden’s Tv Light] Call-Service attempted without connection to server.
3 Apr 09:40:05 - [error] [api-call-service:Outside Lights Off] Call-Service attempted without connection to server.
3 Apr 09:40:07 - [info] [server:Home Assistant] Connecting to
3 Apr 09:40:08 - [info] [server:Home Assistant] Connecting to
3 Apr 09:40:08 - [info] [server:Home Assistant] Connected to
