I am trying to create a flow that will grab data from separate entities. The first will tell me how long someone slept in hours and minutes and the second will show the sleep score.
How can I display both in 1 notification. Here is my attempt at the flow:
[{"id":"43eaf1c4e1bc3c15","type":"time-range-switch","z":"cde85205.f62c6","name":"5:00 am - 12:00pm","lat":"","lon":"","startTime":"05:00","endTime":"12:00","startOffset":0,"endOffset":0,"x":430,"y":1680,"wires":[["b810d7c503d587c0"],[]]},{"id":"d3b992563f8d7f0d","type":"server-state-changed","z":"cde85205.f62c6","name":"Matthew is Awake","server":"6e751b1b.8f17c4","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.jonathan_s_sleep_stage"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"awake","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":230,"y":1680,"wires":[["43eaf1c4e1bc3c15"],[]]},{"id":"b810d7c503d587c0","type":"trigger","z":"cde85205.f62c6","name":"","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"90","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":610,"y":1680,"wires":[["7d8a8a5f9da9fe03"]]},{"id":"7d8a8a5f9da9fe03","type":"api-current-state","z":"cde85205.f62c6","name":"Time Slept","server":"6e751b1b.8f17c4","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.jonathan_s_time_slept","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"slept","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":810,"y":1680,"wires":[["d9af8095adb54534"]]},{"id":"a11da70c48a3b8bc","type":"inject","z":"cde85205.f62c6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":600,"y":1740,"wires":[["7d8a8a5f9da9fe03"]]},{"id":"d9af8095adb54534","type":"api-current-state","z":"cde85205.f62c6","name":"Sleep Score","server":"6e751b1b.8f17c4","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.jonathan_s_sleep_quality_score","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"score","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":1760,"wires":[["c380d5a0a246b4dc"]]},{"id":"c380d5a0a246b4dc","type":"join","z":"cde85205.f62c6","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":990,"y":1680,"wires":[["f93a4703bf9ddaa2","63026a4ca16c3764"]]},{"id":"f93a4703bf9ddaa2","type":"function","z":"cde85205.f62c6","name":"","func":"// Calculate hours slept\nlet sleptMinutes = msg.payload.slept; // Minutes from the first api-current-state\nlet sleepScore = msg.payload.score; // Score from the second api-current-state\n\n// Calculate hours from minutes\nmsg.hours = (sleptMinutes / 60).toFixed(2);\nmsg.score = sleepScore; // Assign the score directly\n\n// Prepare the message for notification\nmsg.message = `${msg.hours} hours and score of ${msg.score}.`;\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1120,"y":1680,"wires":[["0fde64a0845b56af","2103974d058099ba"]]},{"id":"63026a4ca16c3764","type":"debug","z":"cde85205.f62c6","name":"debug 106","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1150,"y":1620,"wires":[]},{"id":"0fde64a0845b56af","type":"api-call-service","z":"cde85205.f62c6","name":"Notify","server":"6e751b1b.8f17c4","version":7,"action":"notify.all_iphones","data":"{\n \"title\": \"Jonathan's Sleep\",\n \"message\": \"{{ payload }} hours and score of {{ score }}.\"\n}","dataType":"jsonata","x":730,"y":1940,"wires":[[]]},{"id":"2103974d058099ba","type":"debug","z":"cde85205.f62c6","name":"debug 107","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1280,"y":1660,"wires":[]},{"id":"6e751b1b.8f17c4","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
