Node-red outgoing email (solved)
Im trying to get the node-red email function to work and am having no luck with it. The email sends as expected but the body of the email just contains “undefined”
At the moment I am testing with a temperature monitor. I run the output to a function that contains
 msg = {
        payload: "The Temperature is "+msg.payload+"C",
        topic: "Temperature email",
        to: "MY.EMAIL.HERE",
        qos: msg.qos,
        retain: msg.retain,
        _msgid: msg._msgid,
return msg;
Then out of that function into the node-red email (and a debug node)
The debug shows the correct msg settings and says it is sending the message.
I did several searches but did not find a solution, has anyone run into this before?
I should note that I have tried it with my primary email server which has spam and virus scanning then to make sure it was not on my server I changed it to a test email server which is just a stock sendmail config with no spam/virus detection and get the same message. The email server is not encrypted so plain port 25 email.
Well I found the problem. Turns out in my zeal to play with new palettes I installed an email contrib that was causing issues.
Removed it and everything went back to working.
